JVC JLC42BC3000 screen froze on "JVC" logo.
  • vinceroger69
    replied
    Re: JVC JLC42BC3000 screen froze on "JVC" logo.
    maybe send these a email see if they do one for your main board
    http://www.ebay.com/itm/EEPROM-FOR-J...item3a814cdf0e
  • Langston
    replied
    Thanks everyone for the replies. After doing some more digging it seems it most likely is an eeprom issue. I called shop jimmy to try and purchase one but they do not carry them. They also said given the symptoms its most definitely an eeprom. I think I see several eeprom's on the main board but I'm not sure. Is there a way to test them to see which is faulty? Do I just start shooting in the dark and replacing one by one? Is there a inexpensive reliable source for these? Thanks again!
    D-
  • retiredcaps
    replied
    Originally posted by budm
    BTW, the main board is made by AMTRAN which is the same company that makes board for VIZIO which has history of bad Voltage regulators 1117 series. This JVC is just a rebadged.
    Vizio also has numerous eeprom problems.
  • retiredcaps
    replied
    One ebay seller sells a service to repair the main board with exact symptoms. OP might want to send an ebay PM asking what part is replaced? Eeprom? main IC?
    http://www.ebay.com/itm/252044041215
    Shopjimmy, when searching for 3642-1542-0150 returns, (possibly an eeprom problem)
    http://www.ebay.com/itm/251317871119
    Caps on main board still could be bad and have too much ripple which might have caused the eeprom to go corrupt?
    replied
    "5.2VSB - 5.8 VDC - Red" This one is probably an error because the other two are the same.
    Your Voltages look normal but I do not know what the status pin is should be HIGH or LO for normal operation, right now it is sitting LO.
  • CapLeaker
    replied
    you have an ESR meter or an oscilloscope to check the caps?
  • Langston
    replied
    Originally posted by Langston
    Hi, I'm trying to repair the logic board " 3642-1302-0150 " on my JVC LCD tv. I'm looking for any help possible. I've repaired another in the past by mailing off the logic board but I'm more interested in learning how to repair it myself. I have the back cover removed, multi-meter, pencil, paper, and a double shot of espresso ready in hand. I do not see any puffed capacitors or burn marks. Currently the screen lights up and the JVC logo sits in the screen. No buttons work and TV only powers down if I unplug it. Where should I start? Thank you in advance-
    Langston
    http://www.shopjimmy.com/catalogsear...VC+JLC42BC3000
    There are at least two fuses on that main board that I can see, also Voltage regulator ICs that you need to check.
    Pictures provided by shopjimmy.
    Read the link below my signature on how to test and report the readings that will be easy for us to understand.
    Thank you budm. I assume the fuses your talking about are F1 and F2?
    F1=5.28VDC on both sides of gold terminals
    F2=12.29VDC on both sides of gold terminals
    These are the voltage regulators that I located, there may be more that I'm not seeing.
    1084-VI= 5.22VDC VO=3.28VDC GND=2.05VDC (U5)
    1117 #U9: In=5.23VDC Out=3.28VDC ADJ=2.02
    1117 #U3: In=5.26VDC Out=3.29VDC ADJ=2.04
    949D32: In=12.25VDC GRN=0.00 Out=5.04 (U17)
    Also (U5) 1084 only has 2 of the 3 pins attached to the board. I've attached a picture showing this. the voltage on the detach and on the solder point are both the same. It may be designed this way.
    Here are the voltages for the 14 pin connecter:
    VBR_B - 3.22VDC - Orange
    Status - 0.0VDC - Red
    On/Off - 2.63 - Brown
    On/Off - 3.18 - Black
    12V - 12.27 VDC - White
    12V - 12.27 VDS - Grey
    12v - 12.26 - Purple
    GND - 0.01VDC -Blue
    GND - 0.01 VDS - Green
    GND - 0.01 VDC - Yellow
    GND - 0.01VDC - Orange
    5.2VSB - 5.29 VDC - Brown
    5.2VSB - 5.28VDC - Black
    replied
  • Langston
    replied
    Attached pictures-
  • Langston
    started a topic JVC JLC42BC3000 screen froze on "JVC" logo.
    Langston
  • abajor
    A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
    by abajor
    Having this very weird issue.
    The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
    I swapped with a working screen from an A2141 waiting for parts.
    The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
    The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
    04-27-2024, 01:37 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • kotel studios
    Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
    by kotel studios
    Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
    State I got it in:
    Squealing from the PSU
    After logo I get a blank screen
    After 10 seconds of having a blank display w/ backlight the TV dies
    Give it 7-10ish seconds again and it starts to bootloop.
    What I did so far:
    Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
    Checked all voltage rails:
    5VSB - 4.8V
    AMP+13V - 14.4V
    13V - 12.98V (in manual 12V)...
    09-21-2025, 02:00 AM
  • Yolojays
    HP Zbook Flash Screen Logo question
    by Yolojays
    Hello everybody,
    I cleared the Bios password on a HP ZBook 15u G3 Laptop (i5-6200U​) using HPUnlocker tool. My question is, the laptop has a Custom Boot Logo and can't find a way to restore it to the original HP logo. Anyone by chance know a way to do it?
    What I tried and checked:
    -No custom logo option in bios
    -updating the bios did not help
    -Hp client management library method id not work
    -ereplogo utility di not work
    Thanks in advanced....
    03-15-2024, 10:04 AM
