Vizio - XVT472SV
  • jasenpeters
    • Sep 2015
    • 53
    Re: Vizio - XVT472SV
    budm, and all....
    Just want to let you know, it's been nearly 5 months of consistent use of the TV and still no problems, since the day I jump started it with the 1k ohm resistor.
    All is good, and grateful.
    Also, someone just gave me (they are throwing it out) a LG 47" (47LN5700) TV, where they say the LED's are not working. So, I may be back (a new thread of course) for more.....
      Thanks for the follow-up.
      • jasenpeters
        • Sep 2015
        • 53
        budm, et al....
        Just want to let you know that as of Dec-2018 (over 3 years) the Vizio is still "kickin'"
        No problems since the "fix" back in Sept 2015.
        I just read the thread again, and find it amazing that from a simple jumping of a resistor as in performed in the thread,
        the TV has behaved normally since.
        Since then (2017) I acquired another TV, LG in this case, and it was bad LED's.
        Make sure you get the proper bright White LED's.
        I overlooked this and got dingy yellow types, but the image is tolerable.
        Not worth going back in. Not the "main" TV.
        And recently, a few days ago, another TV, Samsung, on the roadside.
        Talked to the owner, he just put it out minutes before I saw it in my neighborhood.
        I'll have a separate post on that one.....
        Just want to say thanks for all the good advice.
        $500+ TV's for a little know how and patience is worth the fun and adventure of troubleshooting.
        Jasen
        • Bugman1400
          Vizio E470VL got +5VSB, but no 12V
          by Bugman1400
          EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
          +5VSB= +5.09
          12V= +12.18
          PS_ON= +2.25
          I_ON/OFF= +3.27
          LAMP= +3.18
          DIM= +2.97
          Any more testing I can do on Main board or is it just a replacement?...
          09-04-2022, 09:19 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • прямо
          Viper22A 5VSB circuit
          by прямо
          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
          01-13-2024, 07:05 PM
