Hi All
As above, no red led nothing! Seems quite a common problem with bad mosfets and snubbing capacitors, but with the exception of FS801S keeping on blowing (rather than FS802S in almost all other posts!).
Having researched the power/inverter board BN44-00264A, and reading through posts on badcaps, I have replaced the following and their location;
CI890 220pF 1KV
CI891 220pF 1KV
Q1820/Q1821 7N50U x 2
FS801S fuse
After replacing these and applying power the same FS801S fuse blew again!
I removed the remnants of the fuse and had a look over the board and wondered whether one of the transformers could be at fault? The transformer at TI804S is highlighted and I took measurements across the pins in the red box. Pin 1 is at the bottom with pin 4 at the top, meter set to auto range;
1-2, 1-3, 2-4, 3-4= all 1.51 kOhm
1-4 = 3.03 kOhm
2-3 = Short (000.1 kOhm)
Comparing wit the other transformers, there are only measurements showing between pins 1-2, with no other readings on any other pair of pinsI hope this makes sense?
After the FS801S blew I took readings across the 2 x 220pF capacitors which were CI890 = 6.9 MOhm CI891 = 8.9 MOhm
I hope there is enough information to go on! I've taken the pictures in sections to try to show in enough detail.
Thanks in advance.
CI890 220pF 1KV
CI891 220pF 1KV
FS801S fuse
1-4 = 3.03 kOhm
Thanks in advance.
