Question about Sharp LC-46D85UN Power Supply
  • kevinm34232
    • May 2012
    • 1884
    After opening TV, when plugging TV in a saw a part burning which turned out to be C7816 which goes across pins of D7806. I removed this burnt cap (it actually crumbled into dust), which I believe looked similar to the caps in the last pic.
    Since I cannot identify it, does anyone have a schematic for this board, or can tell me if it is even necessary. The TV turns on now that the burnt cap was removed. Thank you.
    Re: Question about Sharp LC-46D85UN Power Supply
    It is the snubber for the diode. Without it, the diode will fail early due to higher peak voltages.
    • kevinm34232
      • May 2012
      • 1884
      Is there a way I can determine the right specs for it?
      Diode is a STTH8R06FP
      https://cdn.badcaps-static.com/pdfs/...2456fa105e.pdf
      • kevinm34232
        • May 2012
        • 1884
        Found some info on another site, replacing C7816 with
        part # 561R10TCCT22 (Ceramic Disc Capacitors 1Kvolts 220pF 5%)
        Hope this helps someone in the future.
          That is the snubber cap which has the same failure mode as in many Samsung power supplies board.
          Good fix.
          • kevinm34232
            • May 2012
            • 1884
            It was completely burned to a crisp. I had an older Samsung with the same problem a while ago. I replaced with the best cap I could find.
              I would use higher than 1kV rated as the cap may have failed due to low rating (maybe peak transients exceeding 1kV?)
              • kevinm34232
                • May 2012
                • 1884
                The part I ordered for replacement is this:
                http://www.mouser.com/ProductDetail/...W5sIx2JA%3d%3d
                This one is huge, did they send me the right part?
                  Lead Spacing: 9.5mm
                  What do you think?
                  • fzabkar
                    • Mar 2009
                    • 772
                    I'm still downloading it (67MB !!!) but the following service manual has the same capacitor and diode circuit references:
                    • kevinm34232
                      • May 2012
                      • 1884
                      What is the difference in this part compared to the one I ordered, besides the size?
                      • kevinm34232
                        • May 2012
                        • 1884
                        I was looking towards the bottom where it said width 4mm.
                        • fzabkar
                          • Mar 2009
                          • 772
                          I haven't seen the circuit, but if the capacitor is directly across the diode, then its rating should be related to the diode's own VRRM spec, which is 600V. Therefore ISTM that the capacitor's 1kV rating should be ample, and that a spike should kill the diode before the capacitor.
                            That's probably the thickness of the device.
                            • kevinm34232
                              • May 2012
                              • 1884
                              So this part will work then?
                                Most likely. Although the rating of many types of capacitors has to be derated if the slew rate is very high. But yes, in theory, 600V should be ok, a higher rating will not hurt.
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  I'm not suggesting that there is anything wrong with a higher rating. In fact it is preferable. All I'm saying is that 1kV should be more than enough, allowing for derating factors, as you have said.
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    FWIW, here is the APFC section from a different Sharp model:
                                    • cprem
                                      • May 2013
                                      • 7
                                      Did replacing C7816 fix the problem of set having no power?
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                        by sam_sam_sam
                                        07-01-2024, 06:34 AM
                                      • shamsudeen
                                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                        by shamsudeen
                                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                        07-19-2025, 07:14 AM
                                      • CMCM
                                        Russound CA4 Power Supply Repair
                                        by CMCM
                                        Hello Everybody,
                                        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                        The outputs marked 12v and 20v are all measuring only 1v.
                                        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                        The capacitors physically look clean (no bludgesor leaks) and...
                                        07-03-2025, 01:12 PM
