I have a shorted s1172b regulator 3.3 output it is a hsop 6 smd.I am looking for a replacement since you have to order 2000 to get it.I found one but not sure it it will work part number s-1142b33l-e6t1u this one I can order one for $1.52.Any input would be appreciated.thanks
Working on a Tc-p50s30
Re: Working on a Tc-p50s30
I don't know but you could just get it from Sears IC8702 , C0DBAFG00029
http://www.searspartsdirect.com/part.../0057/528.htmlComment
When i check for resistance from pin 6 or 3 to ground i get less than 1 ohm.also when i check pin 6 and 3 to pin 2 or 5 there is resistance.since pin 2 and 5 are ground.at first i thought that ic was bad but when i pulled and did same tests no resistance between pins and ground on the chip by it self.but on the pins with no chips the readings show short between pin 3 and 6 to ground.I am thinking bad caps.here is the schematic of the chip.it is not very clear but that is all i could findComment
I removed the caps and like to be expected Panasonics caps usually don't go bad still have short.i traced the shorted line looks like it is going ic 8000.If that is bad this board is going into the I don't have equipment to replace it box.When I get ird bga machine then I will put back on the work bench.Comment
by SuperAmanI have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...08-31-2024, 07:30 PM -
by MireniaHi everyone,
I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled... -
by sekhar203Hello Everyone!
I'm facing an issue with a MacBook A1706 (820-00923-05) The keyboard stopped working, I replaced it with a new keyboard, after replacing a new keyboard it worked perfectly for some time after that it stopped working.
Any guidance and advice on how to approach this problem would be greatly appreciated06-17-2023, 01:32 PM -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by MMH3Hello,
i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
Never ever i experienced problems with that.
Now i have one 5050sff machine, where this jumper isnt working at all.
I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
The history of the machine is that i used it in my office... - Loading...
