LG 32LS4300 , no red light , no power
  • angel-boy
    • 550
    • Romania
    - mainboard - eax64664903 1.0
    -power source - eax64560501 - 1.6
    is no red light when power plug in, i dod not find schematic
    i edit photo with voltage . If i remove cable between power and main. i have only 3.5v
    Hope you can help me.
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 32LS4300 , no red light , no power
    By the looks of it you have a faulty mainboard.
    If you jump ps-on and inv-on do the backlights come on?
    • angel-boy
      • 550
      • Romania
      You mean pwr-on with inv-on , no blacklight
      p-dim , or a-dim with inv-on , no blacklight
      • Hamie
        • Apr 2014
        • 1383
        pwr-on to inv-on.
        • angel-boy
          • 550
          • Romania
          No blacklight .
          • Hamie
            • Apr 2014
            • 1383
            What about if you also give voltage to p-dim aswel?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I think you have to bridge with a 100 ohm resistor the 3.54Vdc STD-BY - to the PWR-ON, check if you are getting 12Vdc and 24Vdc then using another 100 ohm resistor bridge from 3.54Vdc STD-BY to INV-ON and check if Backlights come on.
              • angel-boy
                • 550
                • Romania
                PWR-ON allrealy have 3.5v , i have 12v and 24v, check the photo.
                i will try 100ohm rezistor between pwr-on to inv-on
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  OK...I did not look at the photo before.....I'll have to agree with Hamie...looks like a Main Bd issue...
                  • victor_cj
                    • May 2015
                    • 90
                    • Romania
                    Check voltage/software at IC401 24C256, IC1401 MX25L8006E from main board. In the worst case you have IC101 LGE2111A-T8 faulty.
                    The art of fighting without fighting
                    • angel-boy
                      • 550
                      • Romania
                      IC1401 MX25L8006E have 3.5v pin 8
                      IC401 24C256 - no voltaje, but when try to measure a sound is hearing from IC101 LGE2111A-T8
                      and IC101 LGE2111A-T8 is a little hot
                      after 5-10 min , i want to measure againg and i notice that the red light is on, and now is starting.
                      • fzabkar
                        • Mar 2009
                        • 772
                        A Google search suggests that the same mainboard (EAX64664903) is used in the 32LK330U:
                        http://elektrotanya.com/?q=showresul...at2=schematics
                        Also, the 32LM3400 uses the same PSU (EAX64560501):
                        • pierce012
                          • Oct 2022
                          • 6
                          • Malta
                          Did you ever solve this?
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • lapfix
                            HP OMEN NO power no light
                            by lapfix
                            HP OMEN : DAG35DMBAD0
                            NO power ,no short ,no corrusion
                            Consumption : when charger plg in = 0.004 amp
                            Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                            when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                            No light at power button led
                            All coils resistances :
                            Pl 2001 =3v measured with kohm.
                            pl 2004 = 5v measured with kohm
                            pl 6001 = 49.7ohm
                            pl 4012 = vccsa = 24.4 ohm
                            pl 3001 =...
                            11-03-2025, 07:48 AM
                          • ipatch
                            troubleshooting microsoft surface pro 4 no power no led charge light
                            by ipatch
                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                            10-05-2023, 11:59 AM
                          • russpall
                            LG 39ln540v - red light flashes twice, no power to LED driver?
                            by russpall
                            Hi there,
                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                            08-27-2024, 01:07 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
