Sony KDL-52XBR9 LCD TV 6 red flashes
  • tech2014
    • Aug 2014
    • 807
    I have an LCD tv that does the following:
    I turn on the power, the backlight/screen comes on for a couple seconds, then shuts off, turns on again for a couple seconds, shuts off, then on and off again. Then the tv shuts down and i get 6 flashes on the power LED. See pics of inside tv below:
    The error codes are for a backlight problem. Manual says D4N board, main board , inverter board,or power supply. I have tried removing connectors from each board one at a time(other then the main board), and I still get the 6 red flashes.
    I get nothing on the bal error or inv error pins, stays near 0v. I do get 3.2V on back_light pin for a couple seconds then goes to 0 volts. The backlight pin gets its voltage from the main board, so I would assume the main board is ok.
    Can anyone suggest anything I can do to narrow down the board causing the problems. Thanks in advance.
  • tech2014
    • Aug 2014
    • 807
    Re: Sony KDL-52XBR9 LCD TV 6 red flashes
    All the voltages come up as they should on the power supply, albeit for a short time. 3.3v standby is always there so p/s should be good. Any suggestions?
    • Maklaud
      • Sep 2015
      • 56
      • Russia
      Try service mode.
      • tech2014
        • Aug 2014
        • 807
        I tried and for some reason I can't get into service mode.
        • Maklaud
          • Sep 2015
          • 56
          • Russia
          Try
          • Maklaud
            • Sep 2015
            • 56
            • Russia
            If no backlight then you need to disassemble the matrix.
            Lamp check.
            • Maklaud
              • Sep 2015
              • 56
              • Russia
              And invertor check.
                Keep the DCV meter on CN6903 pin 1 (inv error) of the D4N Inverter board before the power switch is activated and after the power switch is activated.
                I have a feeling one of the two inverter boards (D3N, D4N) is not working.
                • Maklaud
                  • Sep 2015
                  • 56
                  • Russia
                  Enable INV Voltage = ?
                  • tech2014
                    • Aug 2014
                    • 807
                    thanks guys. I will check and get back to you with the results.
                    • tech2014
                      • Aug 2014
                      • 807
                      Hi budm. I tested pin 1 of CN6903. When I first plug in the tv, the voltage is 6.3v. After about 30 seconds it goes to 0v and tv clicks. The LED flashes red and voltage is 0v at pin 1 of CN6903. Turn power on and voltage goes to 6.3v then a few seconds later tv shuts off and voltage on pin 1 drops to 0v.
                        I look at XBR6 manual which has similar setup as the XBR9.
                        The INV_ERROR and the BAL_ERROR pins (CN6204, CN6201 on the power supply board) normally LOW as you have indicated in post 1.
                        But do you see those two pins stay LOW and never did jump up high at all?
                        • tech2014
                          • Aug 2014
                          • 807
                          Maklaud- The pic you posted with the 470 ohm resistor is that to test the backlight and force it to stay on.
                          • tech2014
                            • Aug 2014
                            • 807
                            Hi Budm. The voltage stays at 0 volts on BAL_ERROR, but when backlight comes on the voltage jumps from 0 to between 0.6-2 volts on the INV_ERROR pin.
                            • Maklaud
                              • Sep 2015
                              • 56
                              • Russia
                              Disassemble the matrix.
                              You need another person.
                              90% that the problem is in the lamps.
                              Don't be afraid!
                              • Maklaud
                                • Sep 2015
                                • 56
                                • Russia
                                What model is matrix?
                                • tech2014
                                  • Aug 2014
                                  • 807
                                  Hi Maklaud. I appreciate the help but I am not going to disassemble the matrix, thats too much work. I want tot rule out the panel in other ways.
                                  • tech2014
                                    • Aug 2014
                                    • 807
                                    ok with D4N board connected to the D3N board, I measured the inv_error pin on D3N board and it measures 6.3V. When I remove the connector from the D4N board on the D3N board, the voltage on the inv_err pin measures 0V. I guess this means D4N invertor board is defective. Since there is a schematic, is it possible to repair rather the replace the whole board.
                                      "When I remove the connector from the D4N board on the D3N board, the voltage on the inv_err pin measures 0V." I am curious, did you still see the screen flashes on for seconds also? It should if DN3 is OK.
                                      • tech2014
                                        • Aug 2014
                                        • 807
                                        Yes the screen does flash for a second.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • joliver82
                                          Sony XR-65A95L no power due to logic board issue
                                          by joliver82
                                          Hi guys!
                                          I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
                                          First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
                                          When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
                                          Today, 04:57 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
