Panasonic Th-42PX75U Question
  • eagle00799
    • May 2012
    • 322
    Hi guys, I need some advice with this tv. I got it completely dead, no lights, no clicks, no signs of life. After some research I found this is a common problem with this tv so I bought the kit for the power supply which consisted of 2 ceramic fuses, 1 mosfet transistor and 3 diodes. I installed the fuses and diodes without any problems but when I tried to bend the middle leg of the mosfet it broke off, so I soldered it back together and installed it. When I plugged the tv in the mosfet let out a loud pop and a bit of smoke. The fuses didn't blow, they are still good. So my question is
    1) could the soldering of the middle leg cause it to blow or do I have other problems?
    2) When I took the old mosfet off the heat sink there was small evidence of thermal paste so I applied some Arctic 5, Would there be any problems with this?
  • sordids999
    • May 2013
    • 2160
    Re: Panasonic Th-42PX75U Question
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • eagle00799
      • May 2012
      • 322
      Here are some pics of the boards and a close up of the mosfet that popped. I have a new mosfet but don't want to install it if it's going to do the same thing.
      • eagle00799
        • May 2012
        • 322
        I just took the mosfet that popped out of circuit and compared it to the new mosfet I just got and they read the same. So not sure why it popped, soldered leg couldn't handle the power??
        • eagle00799
          • May 2012
          • 322
          Can someone tell me what the pink pad is called that's between the fet and the heatsink? maybe isolation pad? There is a small hole in it and I believe the metal back of the fet is shorting out on the heatsink causing the pop. I thought the metal backing on the fet was ground but apparently not?
            "SIL" pad, it's thermally conductive but electrically isolating. It MUST be installed. The metal back of the FET is almost always the drain, which is typically the most positive voltage for an N-channel FET.
            • eagle00799
              • May 2012
              • 322
              Thanks for the reply Tom66, So if its using the pad is thermal compound needed or maybe just an adhesive? If I fold the top over just enough to cover the hole it should be fine?
              • eagle00799
                • May 2012
                • 322
                Update: Found a "SIL" pad on another bad board I had laying around for parts. Swapped the pads and put in two 6.3amp fuses I had laying around in place of the 8amp fuses and plugged it in and it now works perfectly. Thanks for the input guys, your help is indeed priceless.
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • redbaron1007
                  Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                  by redbaron1007
                  I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                  Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                  09-09-2025, 11:10 AM
                • AppleLover123
                  Asus X712EA 3 volts after the first mosfet
                  by AppleLover123
                  Hey guys,
                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                  Now i thought something...
                  12-15-2024, 07:49 AM
                • MicroSMD Lab
                  ASUS ROG Zephyrus GPU Mosfet repeat failure
                  by MicroSMD Lab
                  The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                  I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                  01-10-2024, 06:36 AM
