sony kdl55ex720 (led error 4)
  • gandhi55
    • Mar 2012
    • 3
    • United Kingdom
    i have a sony kdl55ex720 that has backlight problem. The backlight usually comes on for a second or two but sometimes not at all. Flattening the bl_error line going to main power board clears the error (steady green stby light) but makes no difference to the backlight, it still goes out after a second or two. While the backlight is on its hard to tell for sure but i cant see any dark area's, i'm hoping its a board fault not the led's in the lcd panel. There is no change on pin 2 (fail) of the bd9276 on the LD board, cant find any info on the chip so i dont know what triggers the fail signal.
    Does anyone have any info on this chip ?
    Also i cant find a readable schematic for the G8 led power board ?
    Lastly the led vcc from the G8 board is 203v while backlight is lit, then 181v when off. Is 203v too high ?
    Any help would be greatly appreciated.
    Re: sony kdl55ex720 (led error 4)
    Disconnect the LED connector and check the pin that you are reading the 203VDC again to see if it goes a lot higher than 203V, if it goes up just a little bit then more likely you have an open circuit in the LED strings.
    Pictures of your backside of the TV that shows all the boards and the boards will help.
    • gandhi55
      • Mar 2012
      • 3
      • United Kingdom
      Thanks for the reply. I disconnected one of the led strips from the plug and the vcc went up to 260v (which worried me slightly the caps on vcc output are only 250v. I attached a picture of my set if it helps.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • delpiero3
        Sony Vaio SVS MBX-261 board failure
        by delpiero3
        Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
        Nevertheless, let's say, i don't come as a total beginner.
        I have this old laptop, which suit perfectly my needs, with the...
        10-29-2024, 06:16 AM
