39L22U Toshiba LED TV
    Re: 39L22U Toshiba LED TV
    Funny... Mine is a 80w.
      Just replaced the fuse. Still doesn't turn on but can confirm the 5v is working.
        Measuring 174v on the long caps now.
          PSU front and back.
            With the 5V being back on the PSU and the mainboard plugged in, does the STBY LED do something on front of the TV when you try to turn the TV on?
            How the flow of power goes:
            The PSU has 5V STBY, that is always there, regardless. That goes to the main board. When you turn the TV on, that is get sent back to the PSU to PSon and BLon, turning on the whole power supply and the backlights.
            So what you want to do here is to measure the PSon voltage, to see if there is a main board problem or not.
            To check the PSU, unhook everything but the backlights from the PSU. Take two 1k Ohm resistors and jump 5v to PSon and another one from 5V to BLon. Once you plug the PSU in, all the voltage rails should be up and the backlights should be on.
            I still wonder if something else is shorted on the PSU. It just would be too nice for the fuse to fail.
              That's fine if you're experienced and can handle the heat, but 30w is fine for anything like this, using a 60w the OP could just end up completely ruining the board, thats IMO anyway.
                I've inserted 1K ohm resistors from the 5v connections to BLON and PWON and no light comes on.
                  The wires go the main board are disconnected first?
                  How about the 12Vs on those 12V pins, do you get those Voltages?
                    Yes.. I've just taken the end of the ribbon from the PSU that goes to the video board and inserted the resistors to the plug. Essentially just making a direct jumper to the PSU.
                      Checking 12v voltages now...
                        Reading 11.7 v on the 12v connections.
                          Is my connection in the picture above correct?
                            I can't tell, as there are 2 green and 2 red wires. You have to trace them and make sure they are correct
                            However, now check all the voltages and post them with the pinout. Are the backlights plugged in and are they on?
                              backlights are plugged in, it does not turn on.
                              BLON 5v
                              DIM 0v
                              ACD 5v
                              PWON 4.9v
                              5vcc 5v
                              12cc 11.9v
                              12Va 11.9v
                                I accidentally touched the DIM & ACD when checking voltage to ground, the backlight did come on then.. What is ACD?
                                  ACD = AC Detect, the signal is used to tell the main board the condition of the incoming AC feeding the TV.
                                  "DIM 0v" 0v = no backlights. So have everything hook back up but not the DIM wire connected to see if the backlights will stay on. 0V on the DIM pin is not normal.
                                    With 1k jumpers in place still no backlight..
                                      What is the DCV at the DIM pin? 0V = NO BACKLIGHTS.
                                        It reads 0V
                                          And just to be clear, that's 0v with and without the jumpers.
