Lg pdp60r1
  • Jnorthway
    • Aug 2015
    Lg pdp60r1
    Ok so I've been having a problem with my lg pdp60r1, it just started to make a clicking noise more than usual when powered on. Stand by light goes off, click from relay and light comes back on.I've managed to unplug for a significant amount of time and re try powering it on. It has powered on a couple times but it shuts back off with the click of tthe relay. Then last time it stayed on and has been on for about 1 hr.going to leave it on for a while and try powering it off but looking to fix this problem.
  • Jnorthway
    • Aug 2015
    Re: Lg pdp60r1
    Sorry model number is actually 60pk250
    • sordids999
      • May 2013
      • 2161
      • uk
      Re: Lg pdp60r1
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • sordids999
        • May 2013
        • 2161
        • uk
        Re: Lg pdp60r1
        checked voltages including VS/VA ?
        • valvashon
          Repair Success! Middle Atlantic UPS2200R-IP
          by valvashon
          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
          02-06-2024, 12:54 PM
        • Green Probe
          Recapping a Denon AVR X6400h SMPS
          by Green Probe
          (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
          Disclaimer: I'm an amateur hobbyist and will get things wrong.
          Always use caution when working around mains power and high voltage capacitors!
          Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
          SYMPTOMS:
          -No display...
          07-18-2025, 03:36 PM
        • thstuff
          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
          by thstuff
          A) TV initially dead
          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
          12-26-2024, 09:10 PM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
