LG 50" Plasma 50PS30-UB powers on, no picture, no sound
  • niblettr
    • Jun 2015
    • 98
    Re: LG 50" Plasma 50PS30-UB powers on, no picture, no sound
    also, see attached
    • vinceroger69
      • Mar 2012
      • 6714
      #42
      should the test point pins be bridged before you even turn the set on? or dosnt it matter?
      • niblettr
        • Jun 2015
        • 98
        No, just connect everything up like normal first.
        • douellette88
          • Jun 2015
          • 61
          Originally posted by niblettr
          Do you have access to an oscilloscope? If so, check for pretty waveform going from control board to Ysus board.
          I do not unfortunately.
          As for the power wires on the board, I will check it tomorrow after work
          If the voltages read low would you say bad power supply? and if voltages are okay, then bad logic board?
          • douellette88
            • Jun 2015
            • 61
            It's actually the one with white wires. First 4 pins on left read 5.11v and the others are ground which appears to be correct.
            • niblettr
              • Jun 2015
              • 98
              Try isolating the Z sus board then try power up tv. Do you see any change?
              • douellette88
                • Jun 2015
                • 61
                If you are referring to simply unplugging power from the z sus, then yes I have already tried that and nothing changed. But I will go try disconnecting everything from it to double check
                • douellette88
                  • Jun 2015
                  • 61
                  I unplugged both wires going to the z sus board and no change. I feel like we are at a point where I should start trying to replace parts now
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    #49
                    Aye--Go on, Replace parts!
                    But--Which Ones....?
                    Only logical fault-finding will tell ya! Can you confirm ALL the voltages are Correct?
                    These are--
                    Vs, Va, VSC, -Vy and VZBias.--Not all of these are measured with respect to chassis, so confirm with the manual the correct test-points, but are normally marked on the boards.
                    Your fault--(To illogically just replace parts) could be in no particular order-- the Control-Board, the Y-SUS, the Z-SUS or the Mainboard,--Oh yes, the PSU and the Buffer-board could also be at fault, Or the panel itself
                    You takes your pick and pays the price!....
                    Confirm also, you have Va on the lower panel address-board.
                    TELEFIX
                    • douellette88
                      • Jun 2015
                      • 61
                      These are--
                      As I posted earlier in the thread all the voltages I tested were normal. No idea how to test the "lower panel address board", no one has mentioned that yet. I'm just getting frustrated that this tv is not a quick/simple fix like I was expecting.
                      • douellette88
                        • Jun 2015
                        • 61
                        Bump
                        • reaper57
                          • Sep 2014
                          • 216
                          • Norway
                          #52
                          Originally posted by douellette88
                          Bump
                          Check all of the fuses, especially the ones on the power supply, while the TV is off and has been unplugged for a minute or two.
                          Also, can you post a picture of the power supply?
                          Keyboard not detected, press F1 to continue...
                          • douellette88
                            • Jun 2015
                            • 61
                            Pic attached. All the fuses I can see test okay (none reading as OL)
                            • douellette88
                              • Jun 2015
                              • 61
                              Another pic
                              • douellette88
                                • Jun 2015
                                • 61
                                Whatcha thinking?
                                • reaper57
                                  • Sep 2014
                                  • 216
                                  • Norway
                                  #56
                                  I recently had a similar plasma with the same power supply, the problem there where the two mosfets marked in red in the picture bellow. They are actually a common failure on this power supply. Check the resistance between the legs, there should be no shorts.
                                  P.S. Are you sure that the blue fuse, left of the mosfets in red, is reading 0 ohms and not something like 300-1k ohms?
                                  • douellette88
                                    • Jun 2015
                                    • 61
                                    Without removing the board, none of those 3 appear to be showing OL. Would you suspect power supply? And was yours having the same symptoms?
                                    • douellette88
                                      • Jun 2015
                                      • 61
                                      Fuse was at 0
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        I sincerely doubt your power supply to be at fault.
                                        You have VS, VA, 5v standby etc.
                                        Along with vzb, vy and vsc
                                        Your problem is more likely to be the control board or the main AV board.
                                        It may also be, as suggested earlier, the lower address boards are not getting voltages or are faulty.
                                        Or the panel itself.
                                        Going by the fact it's an LG I'd hazard a guess at the mainboard.
                                        • reaper57
                                          • Sep 2014
                                          • 216
                                          • Norway
                                          #60
                                          You're probably right, I must have missed the part about the VS and the VA voltages. Btw, mine also had 5V standby, but that's probably because the blue fuse on my board was at 300-1k ohms.
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
