LG Plasma VZB at half required voltage
  • mpwjak
    mike
    • Aug 2015
    • 5
    • usa
    LG 60PA5500 no picture but has sound.
    YSUS board voltage bad and upper buffer board shorted.
    Replaced all three; VSUS, upper and lower buffer boards.
    TV worked fine for ~3weeks, then no picture again.
    Looked at VZB voltage and see 65v, should be 120.
    Adjustment moves from ~63 to ~66 only...
    Any experience with this? please reply with a potential component fix.
    Thanks!
    PS - I spent several hours looking through threads but didn't see this issue, my apologies if I missed it.
  • mpwjak
    mike
    • Aug 2015
    • 5
    • usa
    Re: LG Plasma VZB at half required voltage
    Also to note; The 65v measured is with out the VSUS board connected.
    • mmartell
      • Oct 2013
      • 3189
      I don't know about this model in particular but some zsus boards receive a +5v from the ysus so I would measure again with allboards connected.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Measure the Vs with the Z-SUS jack unplugged and see if it returns to 165Vdc. If not unplug the Vs from the Y-SUS Bd and see if it returns to 165Vdc. Yes, as mentioned by mmartell 5Vdc generated by the PWR Bd goes to the Z-SUS Bd via the Y-SUS Bd. See if you are getting that. Where is the Va voltage, to the X-Drive Bds at the bottom, coming from the Z-SUS Bd or the Y-SUS Bd or directly from the PWR Bd?
        • mpwjak
          mike
          • Aug 2015
          • 5
          • usa
          Well... I received "New" YSUS, upper and lower buffer boards and powered it up. Immediately heard the upper buffer board making noise, crackling... Powered down the unit and prepared to test voltages. Powered back up and VS and VA were good - upper buffer continued to crackle a bit - VBZ was ~175V (Spec is 120V on this TV). I was able to dial it back to ~140V but that was it.
          The upper board actually sent a small puff of smoke out as it fully expired. Testing showed it was indeed shorted - I suspect it came to me this way. YSUS board -VY is at spec of 185V but the VSC is way low at ~40V, (Spec is 150V on this TV).
          At this point I can't test anything except power board outputs and they are all good.
          Questions:
          #1 Is it possible to blow a board if the potentiometer is cranked completely over when I order new YSUS, ZSUS, upper and lower buffer boards? Is there a best known method to avoid this?
          #2 Is it correct that no pins on a buffer board should short to the outputs where the ribbon cables connect? (I'm having some difficulty seeing the 'Pins that are connected together' from the testing videos.)
          Thanks for the help!
          • mpwjak
            mike
            • Aug 2015
            • 5
            • usa
            Questions:
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
              by sam_sam_sam
              I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
              The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
              Now...
              06-09-2024, 10:57 AM
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
