Phillips 42pfp5532d
  • finntricky
    • Jan 2014
    • 449
    Phillips 42pfp5532d
    got this philips plasma, turns on, screen lights up, and sort of flashes light and dark, there is a buzz from the Y=SUS that seems to be in time with the screen flashing, but no picture, power supply is putting out correct volts, any ideas before i strip it down ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Phillips 42pfp5532d
    Check the Zsus its likely to be causing the issue described, sounds like the Ysus is charging the panel but Zsus isnt working and not discharging the pixels there for no image.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Can you take pictures of the back of the set please and upload them. Dont throw it away either it could be something simple like failed ipm !
      • finntricky
        • Jan 2014
        • 449
        ok, did'nt think Z-SUS was the problem, as it is the little yellow transformer that is buzzing on Y-SUS, but i disconnected the Z-SUS but left the Y-SUS connected and tv turned on, with no buzzing from the Y-SUS, screen never lit up,
        also there was some bad caps, 6 on the power board, that i have replaced, just to rule them out,
        i have added pics
        • sordids999
          • May 2013
          • 2158
          have you tested any voltages ?
          • finntricky
            • Jan 2014
            • 449
            only power supply at the moment, as only just got round to it, and all seem fine
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Right ok do you know how to test for S/C (short circuit) ?
              • finntricky
                • Jan 2014
                • 449
                just had a quick look at this for five mins, looks like Y-SUS is the prob, due to only having
                -20/33 volts on VSC should be 100 i think, volts from power board are fine, dont think its worth spending money on, what do you think guys.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Are there Mosfets on the Ysus. May be worth checking out.
                  • finntricky
                    • Jan 2014
                    • 449
                    quick update on this, i knocked it of the table, broke the screen, so now down the dump
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Shucks!!!
                      • Truncatedhose
                        Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                        by Truncatedhose
                        Greetings all!
                        Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                        Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                        07-04-2018, 10:59 AM
                      • PlasMatt
                        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                        by PlasMatt
                        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                        09-20-2025, 06:50 PM
                      • Salvatore057
                        plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                        by Salvatore057
                        I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                        Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                        I am lost, should I change the YSUS board? Is the YSUS board damaging...
                        04-29-2018, 01:29 PM
                      • JDC
                        LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                        by JDC
                        Make and Model: LG 60PB6650-UA
                        Issue: Turns on, no backlight, can hear static (no channel)
                        I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                        The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                        This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                        09-13-2018, 02:12 PM
                      • legg
                        LG 42PC3 buffer output doesn't follow YSUS
                        by legg
                        LG42PC3D -UD originally with green lamp but no display or audio.
                        Owner says was working, then went 'pop'.
                        All 5V caps bulging. replaced.
                        All PSU output voltages within spec but -Vy is low on YSUS.
                        One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                        eventually shorts DG. Replaced all 3 - -Vy now OK.
                        Y scan buffer test point does not follow YSUS output below -50V
                        Note: This unit seems to expect YSUS output to park at -Vy in between
                        drive signal pattern periods. A replacement drive signal board confirms this....
                        11-18-2021, 11:49 AM
