Samsung LN55C630K1FXZA
  • Captain1511
    • Aug 2015
    • 6
    Red power light comes on when plugged in but no other TV options work.
    TV has been unplugged for 48 hours with no change in operation.
    This situation occurred overnight with no reason or pre-existing problem.
    Removal of rear cover revealed NO burnt, discolored, bulging, or otherwise damaged components.
    Things tested:
    Power Supply Board, Model BN44-00342B
    Voltage In: 119.5 AC
    BD801S (Rectifier) + AC AC - +162.4 119.5 119.5 -162.4
    Fuses Found FS801S (Good), FS802S (Good)
    Diodes DP810,DM801,DM803,DM804,DM809 All tested good in place.
    Large Caps CP802 & CP803 (450V 100uF) tested at 189.9 and 194.1 tested good, respectively, in place.
    First value is with logic board connected, second value in () is without logic board connected.
    When logic board is connected all values pulse on for 3 seconds and off for 5 seconds with the only exception being a 5V constant on CN802 Pin 16.
    CNI802
    12V Pin 1 13.01V (12.55)
    FB Pin 2 Didn't know what to do so left it alone.
    FB Pin 3 Didn't know what to do so left it alone.
    GND Pin 4 Continuity to chassis ground.
    GND Pin 5 Continuity to chassis ground.
    LD Pin 6 Didn't know what to do so left it alone.
    LD Pin 7 Didn't know what to do so left it alone.
    CN802
    B13V Pin 1 13.11 (12.70)
    LAMP_DET Pin 2 Didn't know what to do so left it alone.
    B13V Pin 3 13.12 (12.70)
    SW_INV Pin 4 Didn't know what to do so left it alone.
    B13V Pin 5 13.12 (12.70)
    PWM_D/M Pin 6 Didn't know what to do so left it alone.
    GND Pin 7 Continuity to chassis ground.
    H_SYNC Pin 8 Didn't know what to do so left it alone.
    GND Pin 9 Continuity to chassis ground.
    GND Pin 10 Continuity to chassis ground.
    B5V Pin 11 5.17 (5.19)
    GND Pin 12 Continuity to chassis ground.
    B5V Pin 13 5.16 (5.19)
    B5V Pin 14 5.17 (5.8)
    13/18VS Pin 15 18.97 (18.25)
    A5V Pin 16 5.18 (5.18)
    13/18VS Pin 17 18.97 (18.24)
    POW_ON/OFF Pin 18 Didn't know what to do so left it alone.
    MAIN LOGIC BOARD:
    All voltages are the same as above on the corresponding PCB cable connection coming from power supply.
    CN701 (Connects to the switches on front panel)
    IR Pin 1 3.291 (2.103)
    GND Pin 2 Continuity to chassis ground.
    A3.3V Pin 3 3.296 (3.305)
    MSCL Pin 4 3.297 (3.304)
    MSDA Pin 5 3.298 (3.305)
    KEY1 Pin 6 3.293 (3.302)
    KEY2 Pin 7 3.294 (3.302)
    LED_STB Pin 8 1.603 (2.865)
    LED_CNTR Pin 9 0.00 (2.865)
    A3.3V Pin 10 3.296 (3.305)
    Voltage Regulators Found (3)
    All pulse power at the same rate as above.
    C11
    17-337
    0949BG
    Pin 1 0.000
    Pin 2 3.305
    Pin 3 5.15
    KIA
    7809F
    952
    Pin 1 13.09
    Pin 2 0.000
    Pin 3 9.06
    KIA
    7805AF
    951
    Pin 1 9.05
    Pin 2 0.00
    Pin 3 5.04
    When cable from power supply to logic board is disconnected the backlight comes on as well. Looking for guidance form you guys to get this up and running. Any help is greatly appreciated.
  • CapLeaker
    Leaking Member
    • 8182
    Re: Samsung LN55C630K1FXZA
    Obviously you got STBY voltage going from the PSU to the main board. You have to check if the main board is sending the PSon when you turn the TV on. Once that voltage is there, the PSU should turn on all the rails. So check what you get on the PSon pin and try to turn on the TV.
    • Captain1511
      • Aug 2015
      • 6
      .02 when initially plugged in no action taken. 0.985 volts once power button is pushed. Starts the 3/5 cycle at those two voltages. These readings taken at CN802 Pin 18 POW_ON/OFF.
      • CapLeaker
        Leaking Member
        • 8182
        ~ 1V on the PSon pin is not enough voltage for the PSU to turn on. The problem is on the main board. Take the PSon wire off the connector (cutting wire or take the pin out as you don't want to backfeed). Take a 1k Ohm resistor and force the PSU on by putting the resistor between PSon and 5V STBY. As soon as you plug the TV in, it should start. In order to fix the main board, you either replace it or you are going to be down to tracing back the PSon on the main board.
        • Captain1511
          • Aug 2015
          • 6
          That took care of the power pulses. Nothing happens otherwise. Red standby LED is on. No function through panel buttons or remote.
          • CapLeaker
            Leaking Member
            • 8182
            I guess you need a main board.
            • Captain1511
              • Aug 2015
              • 6
              That seems like an impossible mission! Everyone seems to be out of stock. Thank you for your assistance.
              • CapLeaker
                Leaking Member
                • 8182
                Ummm... if you don't mind, upload some hi res pics from both sides of the main board? Maybe me or someone else can "see" something
                • Captain1511
                  • Aug 2015
                  • 6
                  Attached is a picture of the front and back of the main board.
                  • CapLeaker
                    Leaking Member
                    • 8182
                    Well, I don't see anything obvious. I looked at the fast track SM for this TV.
                    http://www.toms-service-manuals.com/...h=Submit+Query
                    Maybe look at the low voltage supplies mentioned on page 2.
                      Acer Aspire A315-51-3305 Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Aspire A315-51-3305 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-51-3305 boardview and A315-51-3305 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 06:45 AM
                    • karatzdi
                      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                      by karatzdi
                      I know some might say... just buy another one. Sell it as parts..!
                      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                      Spent some time downloading the Service...
                      06-11-2024, 08:38 AM
                    • Pinky Deepak
                      Vizio M60-C3 Left Edge problem
                      by Pinky Deepak
                      I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                      Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                      09-27-2024, 05:11 PM
                    • armoured_smiler
                      Panasonic Tx-40cx400b top left half screen not displaying correct
                      by armoured_smiler
                      Trying to work out if this is TFT problem or TCon issue.
                      The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                      Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                      04-08-2024, 03:40 PM
                    • Sik_6ty_Sixx
                      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                      by Sik_6ty_Sixx
                      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                      02-18-2025, 05:06 AM
