Sanyo DP42849 - Power Supply Issues DPS-260LP
  • wcsd106
    • Jan 2015
    • 57
    I picked up a cheap Sanyo LCD TV from Craigslist this week. It is a model DP42849.
    The TV will not power on and no standby LED is visible.
    With the power supply board pulled, I am not getting the 5v standby voltage at the multi pin connector.
    A voltage reading across the large 150uf/450v electrolytic capacitor on the primary side, shows that I am only getting 170v.
    The power supply board is a DPS-260LP.
    Seems like my problem is more than likely on my primary side.
    Any ideas?
  • wcsd106
    • Jan 2015
    • 57
    Re: Sanyo DP42849 - Power Supply Issues DPS-260LP
    Pictures component/trace side of power supply board.
    • CapLeaker
      Leaking Member
      • 8155
      yep. force the psu on without the main board and see if all voltage rails come up
      • wcsd106
        • Jan 2015
        • 57
        I have tested with the 5vsb pin shorted to the PS_ON pin. Still nothing. With or without the pins connected, I do not have the 5v that should be on the standby pin even when the PSU is off.
        • CapLeaker
          Leaking Member
          • 8155
          so nothing at all on any of the pins? Be careful working on the primary side as there are lethal voltages. Check how much voltage you get on the main filter cap.
          • wcsd106
            • Jan 2015
            • 57
            That's correct. Nothing at all on any of the pins.
            At the main filter cap, I am seeing approximately 170v.
            • CapLeaker
              Leaking Member
              • 8155
              trace the stby voltage rail from the pin back to the secondary of the transformer. Check cap and diode. if that's all good, you have to check things on the primary side. So be very careful there. Kind of need to find a schematic, or you have to trace it.
              Look at D951 something drew a lot of current and it got hot.
              • Chevyman204
                • Apr 2015
                • 3
                Don't mean to jump in but I think i have a ps problem as well. The ps board is the same as pictured above. My bl-on only has 2.4v I think it is suppose to have 3.3v. I can see picture after powered on for one second then it goes black, sound is good. I just so happen to have a second main board from another set that I tried to see if the main board was preventing the bl-on voltage to be low. There was minimal change in voltage. Gained .1v with second board.
                Not sure what to do next, would the bl-on voltage being low by 1 volt prevent the back lights from turning on?
                If I'm not following forum procedure please let me know cause I can start another post.
                I wish the other tv that works had the same ps board so I could just switch it to verify lights. I think the inverter boards are separate on the other set but the main boards are the same.
                • jjaypops
                  • May 2013
                  • usa
                  Ever find out what was wrong chevyman204? I am having the same issue. Thanks
                  • ladywinn256
                    • Mar 2016
                    Any ideas?
                    • ladywinn256
                      • Mar 2016
                      Wondering if anyone has found or had this problem power supply board burns resistor R1 and R2 ???
                        http://www.shopjimmy.com/catalogsear...t/?q=DPS-260LP
                        LP or LPB?
                        R1 and R2 are the through hole 10M Ohms resistors as I can see in the pictures, is that right?
                        What is the board not doing?
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                        • shamsudeen
                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                          by shamsudeen
                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                          07-19-2025, 07:14 AM
                        • CMCM
                          Russound CA4 Power Supply Repair
                          by CMCM
                          Hello Everybody,
                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                          The outputs marked 12v and 20v are all measuring only 1v.
                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                          The capacitors physically look clean (no bludgesor leaks) and...
                          07-03-2025, 01:12 PM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
