Sansui Sled2453w No Standby Set Is Dead
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #61
    Re: Sansui Sled2453w No Standby Set Is Dead
    Also if you did buy the correct Mainboard I have had it where an incorrect Mainboard blew up the Tcon ?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      an oscilloscope would tell you the story now what works and what not.
      • piposarcade
        Samsung UN50KU6300 dead no standby led
        by piposarcade
        01-04-2024, 01:33 PM
        Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
        05-22-2024, 02:07 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • jacobtc
        LG C1 65'' dead standby
        by jacobtc
        I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
        If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
        If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
        I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
        01-29-2025, 04:27 AM
      • piposarcade
        by piposarcade
        Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
        01-04-2024, 12:03 PM
