Sansui Sled2453w No Standby Set Is Dead
  • Sinfury2112
    • Jul 2014
    • 71
    Re: Sansui Sled2453w No Standby Set Is Dead
    eww looks like he will be ordering new board im to blind to do that one lol
    • Sinfury2112
      • Jul 2014
      • 71
      thank you much budm ill replace what I can then go from there
        You will be better off with the new board.
        I had been watching the thread but did not chime in until I was able to get good clear pictures of the board from Shopjimmy to allow me to see how the components are connected on the board to be able to tell you what to test.
        • Sinfury2112
          • Jul 2014
          • 71
          I pulled that mosfet and it seemed to check good no short
            I may have gone open circuit when it pops, or it can be the output of the IC stuck high instead of switching on and off at high frequency so the MOSFET is fully on and caused over current draw. I would not taking a chance since it is not that expensive.
            • Sinfury2112
              • Jul 2014
              • 71
              Hell NOT! Working on the primary is a dangerous thing as you are connected to the mains!
              lol just thought id ask yes I know it is thank you
              • Sinfury2112
                • Jul 2014
                • 71
                replaced power board and mainboard, when I plug the set in now red light comes on, then the blue light comes on, and screen tries light on its own has some colors very blurry which grows brighter and brighter without hitting any buttons. could this be another bad mainboard any help I would be greatful for thanks.
                • Sinfury2112
                  • Jul 2014
                  • 71
                  tv has power and sound now picture is glowing white bleeding to black? cant see any images bad lcd?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #49
                    can you post picture so we can see what you mean.
                    • Sinfury2112
                      • Jul 2014
                      • 71
                      its not doing it now, just has backlight! it isnt bright white now, bleeding to black, just a low backlight all I did was try plug in my computer as a vga source to the pc vga input ill try add some pics
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #51
                        why did you relace the mainboard? have you still got the old one to try? also double check you have reconnect all leads and ribbon cables etc i know ive missed reconnecting the odd one and got odd issues.
                        • Sinfury2112
                          • Jul 2014
                          • 71
                          I replaced mainboard because it had burned spots on it when I got it. it wont even power up with old mainboard ive tried it. the psu was also bad no standby. this tv was surged or was in storm my friend told me I tried old mainboard with the new psu and it wont even power up
                          • Sinfury2112
                            • Jul 2014
                            • 71
                            is the tcon board built into this psu?
                            • Sinfury2112
                              • Jul 2014
                              • 71
                              also checked all the ribbon cables they all seem in place
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #55
                                you will have to post a picture of the back of the tv as some are built onto the panel etc
                                • Sinfury2112
                                  • Jul 2014
                                  • 71
                                  unscrewed the back of lcd where permantly mounted tcon was and a square chip with dozens of pins had hole burned through it that explains it
                                  • Sinfury2112
                                    • Jul 2014
                                    • 71
                                    surge took out every board in this whole tv lol
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #58
                                      must of been a good surge but hey you can keep or sell the power supply and mainboard, you can strip the panel and keep the leds, so alls not lost plus you have proably learnt from doing the set to this point.
                                      • Sinfury2112
                                        • Jul 2014
                                        • 71
                                        yep thanks vincerodger69 alot
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #60
                                          Wow never seen that before what Ic is it, can you take a pic ?
                                          • piposarcade
                                            Samsung UN50KU6300 dead no standby led
                                            by piposarcade
                                            01-04-2024, 01:33 PM
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                            05-22-2024, 02:07 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • jacobtc
                                            LG C1 65'' dead standby
                                            by jacobtc
                                            I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                            If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                            If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                            I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                            01-29-2025, 04:27 AM
                                          • piposarcade
                                            by piposarcade
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                            01-04-2024, 12:03 PM
