Samsung LN40E550
  • stonoguy
    • Jan 2012
    • 65
    Re: Samsung LN40E550
    The connections/connectors were in place......took readings from the "foil" side of the board.
      Well if all the boards are connected, you are not even getting the STBY 5V. You do have AC power to the board, right?
      Meter set to DCV?
      • stonoguy
        • Jan 2012
        • 65
        Those readings ARE with the connectors secured....???? (cold ground)
        • stonoguy
          • Jan 2012
          • 65
          Yes, AC connected......utilizing a variable isolation transformer set to 120 VAC.
            Check the DCV right between the two legs of the main filter cap again to see what you have, it should be around 160VDC.
            • stonoguy
              • Jan 2012
              • 65
              Yep!.......163 VDC.
              • stonoguy
                • Jan 2012
                • 65
                I need some more checking and found a semiconductor shorted....looked up and was told this item (MDD3752) was a MOSFET. Trying to determine what circuit this thing is in and if anything associated with it, is bad too.
                • stonoguy
                  • Jan 2012
                  • 65
                  I ordered the shorted MOSFET...appears to be some type of regulator? The schematic I have for this board isn't right.....FYI,,,just by accident I discovered that the schematic is being used for another Samsung power module also...different part number than the board I have....same schematic, though! I was surprised to find that this part being shorted didn't blow any of the fuses....This set was manufactured in 2014, should all of the power supply caps be replaced? They do not look bloated.
                    Can we see the pictures of this shorted part?
                    • stonoguy
                      • Jan 2012
                      • 65
                      Yeah, you can! Charging battery for camera & will download pix ASAP!
                      • stonoguy
                        • Jan 2012
                        • 65
                        OK...here it is!! It was soldered on the foil side of the board. The only one that was on the board.
                          What section of the board is this part in?
                          Shorted Source pin to Drain pin?
                          • stonoguy
                            • Jan 2012
                            • 65
                            This component is shorted on all 3 of the connections......shorted to each other.
                              That is a Power MOSFET used as a switch to provide switched 13VDC on connector CN802 PIN 1, 3, 5, 7.
                              For that to shorted out you need to check the resistance be tween CN802 pin 1 and GND the main board connected to see if it shows very low resistance.
                              BTW, that should not stop the board from producing the STBY 5V at CN802 PIN 13.
                              • stonoguy
                                • Jan 2012
                                • 65
                                Just looked @ your last post....will do ASAP......FYI: found two transistors that (I thought were shorted E to B, circled yellow in attached pix). Removed one of the transistors from the board, & it measured good. Checked the connection points and found the E/B had a reading of .1 ohms. The other xtransistor checked the same. Collector(s) to ground, OK.>
                                • stonoguy
                                  • Jan 2012
                                  • 65
                                  BTW. What does the SMD printed om the board mean? Have seen this on the board and in other posts.
                                  • stonoguy
                                    • Jan 2012
                                    • 65
                                    OK.... CN802 pin 1 shows 545 ohms....
                                      Those two in the yellow circles are Dual rectifier Common Cathode, the two outside Pins are Anodes which are tied together to form two diodes in parallel.
                                      • stonoguy
                                        • Jan 2012
                                        • 65
                                        Please enlighten me on this...why would the outside connections (2) still read ~.1 ohms with the Dual rectifier removed from the circuit? I wish I had a correct schematic...this would be so much easier......there are some components on the schematic & on the board that I have, in which I am not familiar.
                                        • stonoguy
                                          • Jan 2012
                                          • 65
                                          what is this suppose to represent??.....A transformer? ....Just trying to get a better understanding on some of the unfamilair items on this schematic. Sorry if I'm being a PITA! Please bear with me as it has been a few years since I was expised to these 'new fangled' items on a scematic.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
