Samsung UE40D6530WS Led TV main board repair
  • milen.m
    • Aug 2015
    Hello all.
    I need help with a Samsung UE40D6530WS Led TV. It has no picture and sound, red indicator blinking and clicking sound is heard. There is backlight, but the screen is black (I can see it in a dark room, as the TV tries to start continuously).
    The local TV shop said it needed the main board to be replaced.
    Is there something I can do to repair it, rather than replacing it?
    Some components I can check that are more typical to fail?
    Pictures:
    Best regards,
    Milen
  • milen.m
    • Aug 2015
    Re: Samsung UE40D6530WS Led TV main board repair
    I decided to replace the two electrolytic capacitors on the main board (third picture), but I am not sure what replacement to get.
    The markings are:
    22564
    100
    350
    Any help would be appreciated.
    Regards,
    Milen
    • victor_cj
      • May 2015
      • 90
      You cant use as replacement for the two electrolytic capacitors 100uF 35V :
      EEEFK1V101XP, EEEFPV101XAP, UCD1V101MCL6GS , UCD1V101MNL1GS.
      The art of fighting without fighting
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 7969
        The markings are:
        22564
        100
        350
        Regards,
        Milen
        Check with an Oscilloscope the LVDS signal. While you are at it check all the voltage regulators and then the caps for excessive ripple.
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • Lee M.
          Samsung UN75RU8000FXZA bad main board?
          by Lee M.
          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
          11-08-2023, 07:46 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
