Lg 50PS3000
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Lg 50PS3000
    Hi all, I have this 50" LG plasma here that I was given for free so not too bad. The fault is the tv is troublesome to start, reading up I can see that faulty Zsus can be an issue however with both Ysus and Zsus upluged the set still acts the same way. I checked the Pson signal and its fine and with in spec all the time. I can tell that some one has repaired this tv before as there is some obvious work thats been done on the Zsus. Just wandering if anyone has any info the Psu it will fail to bring the Va & Vs and another other rail over 5v up when its faulting out and it does no seem to be temperature related. Thanks in advance.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 50PS3000
    Right looking into this seems that the 5vstby is sagging so wander whats happening there. Doing some research I can see that some people have had the issue of the 5vstby chip failing better get checking.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Re: Lg 50PS3000
      With the main board disconnected is the 5Vstby still sagging?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Re: Lg 50PS3000
        Do you know how to self test the Pwr Bd?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Lg 50PS3000
          Its ok mate I have found something now, the reason why the 5v sags when main is disconnected is I'm guessing because it isn't being loaded. However found that the mainboard is actually causing the Vs and Va to drop out as it looses the Vson signal to psu however when I flex the mainboard that signal comes back and the tv works. I have made a youtube video and will be posting it when the tv is fixed thanks for the input though.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Re: Lg 50PS3000
            Thanks for the feedback..
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Re: Lg 50PS3000
              No thank you for the input this one was quite a difficult one hopefully a new mainboard sorts the issue.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Re: Lg 50PS3000
                Ok so I fixed the set today, it was the mainboard I will make a separate thread with a diagnoses and repair video linked to it.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Re: Lg 50PS3000
                  Thanks a lot. This is what is keeping this Forum alive.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Re: Lg 50PS3000
                    Haha thanks mate and no problem
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Re: Lg 50PS3000
                      Saw your YouTube video....Great job....Yes I agree...those bloody intermittent faults are the most tedious....Excellent and thanks again.. Regards
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Re: Lg 50PS3000
                        Haha cheers
                        • gshark1
                          Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
                          by gshark1
                          Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
                          12-29-2023, 04:42 PM
                        • alfredomfr1
                          TV Plasma LG 60PN5000 ZSUS 15v missing
                          by alfredomfr1
                          All Voltages are OK except ZSUS 15v.
                          YSUS board disconnected still 15v missing.
                          ZSUS was replaced: 15v missing.
                          Any help will be appreciated...
                          04-29-2022, 11:26 AM
                        • reessi
                          LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
                          by reessi
                          Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
                          Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
                          If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
                          If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
                          12-13-2017, 01:18 PM
                        • Francesc V.
                          Bitfenix Whisper 850W - Only 5VStby and PSON
                          by Francesc V.
                          Hi:
                          I am trying to repair this modular ATX PSU. It only has the 5V Standby and PSON enabled (3.33V).
                          PSON is delivered by (ST9S429-PG14) in pin4. This chip is a Voltage controller but it doesn't seem to trigger any PWM signal to pass it to primary through coils and "move" the big mosfets. Also next to it there is a EST7618 that it also seems a voltage controller.
                          Not sure if in the right direction, but trying to find where PWM signal is generated.
                          Green section seems that could be the "PWM section". It's driven by a...
                          11-27-2023, 05:18 AM
                        • Salvatore057
                          plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                          by Salvatore057
                          I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                          Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                          I am lost, should I change the YSUS board? Is the YSUS board damaging...
                          04-29-2018, 01:29 PM
