TVE LED3212DVDDVBT LED TV No backlight
  • anno
    • Sep 2007
    • 140
    • netherlands
    hi.
    i replaced a diode on mainboard because it doesn`t turned on. Now tv is turning on (green led), but no backlight. on the power supply i have 24 volt on LED+ and LED1 test points.
    there are 2 pairs of wires (2 x red/black) to the panel.
    on mainboard there is a connector labeled 'inverter' , the reading are:
    GND 0
    GND 0
    ADJ 4.5
    BLO 0
    12v 12
    12v 12
    BLO = backlight on? it's 0v so that is not good?
    anyone can help.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: TVE LED3212DVDDVBT LED TV No backlight
    BLO is the backlight on you should be seeing around 3.3v on that. What mainboard is it ?
    • anno
      • Sep 2007
      • 140
      • netherlands
      hi
      it is T.MSD306.9A
      i looked carefully on the board and saw a commonent was loose because i used hotair to remove a diode. i think i used to high airflow.
      it is connected to u3 that is aic2857f a voltage regulator.
      5v goes in and 1.3v goes out. is this output voltage is correct? it looks it goes to the processor.
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • alro7779
        Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
        by alro7779
        Hello, guys!
        I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
        Alex....
        10-03-2025, 05:49 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • Boyxba
        TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
        by Boyxba
        I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
        05-13-2023, 11:47 AM
