toshiba plasma 42hp66 sound ok no picture
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    sound ok no piucture at all screen black
    voltages good from ps
    no visual bad aps on y or z
    no visual burns on y buyffer chips
    tested large fuses on y and z......y board both fuses good....z board 1 OPEN FUSE
    powered tv on for 15 min....y board heat sink very hot to touch....z board heat sink just barely luke warm...not hot at all but not stone cold definitely its doing something since its luke warm
    i have seen where if the chip on the y or z gto bad they are stone cold but in this case the z board heat sink is not stone cold....is luke warm normal?? if the chip is bad can it sill put out heat//???
    any ideas?
  • shelby5041
    • Feb 2009
    • 1505
    Re: toshiba plasma 42hp66 sound ok no picture
    would it be ok to replace the fuse and see how tv acts to pinpoint issue or could that cause more damage to tv?
    i was thinking of didconnecting y to protect it and replacing z fuse and try to power on tv.....
    is this a safe option to try
    • shelby5041
      • Feb 2009
      • 1505
      note...when i pull out good fuse and check for continuity touching both ends of metal ends in fuse socket where fuse goes i get no reading as expected
      but when i pull out open/blown fuse and check for continuity at metal ends in fuse socket where fuse goes i actualyy get continuity.....how can that be? and what does this mean?.....board shorted somewhere?
      • mmartell
        • Oct 2013
        • 3189
        Yes means short circuit. If you pull the ipm on the zsus I bet your short disappears.
        • mmartell
          • Oct 2013
          • 3189
          Wait I just reread that. A better test is to unplug the harnesses to the zsus then test fuse socket to a ground screw. Neither should show continuity and if it does then see my post above.
          • shelby5041
            • Feb 2009
            • 1505
            hi
            without a fuse in the socket ...if i touch both ends of metal mount area i should get no continuity at all period
            but i do get continuity in the socket that had an open fuse
            regardless of any cables connected or not there should be no continuity at all without a fuse in the socket
            correct?
            • shelby5041
              • Feb 2009
              • 1505
              and now that i removed the stk chip on the z board the continuity in the open fuse socket went away
              so im pretty sure there as a short in the circuit....
              • shelby5041
                • Feb 2009
                • 1505
                i have the board out of tv now so cant do that test
                • shelby5041
                  • Feb 2009
                  • 1505
                  one question i do have is i removed the stk chip out of the board....using unconventional way since i dont have proper tools.....since i wasnt able to desolder it off due to two sided board and lead solder...i cut it out using a dremel tool and surgically removed it....but i ruined a few copper pads on top of board...can someone tell me if these pads are important .... here is a pic of z board with stk chip removed and i left the legs..
                  and was not able to remove the inductor copper coil....like budm said its almost impossible to remove but i was able to remove stk without removing it ....couldnt melt the solder since much of the heat just went through the whole coil and not where i wanted it to go
                  i hate lead solder and i hate double sided boards when trying to remove components....
                  • shelby5041
                    • Feb 2009
                    • 1505
                    here is a pic marked with pads that have been ruined...
                    • shelby5041
                      • Feb 2009
                      • 1505
                      hi update
                      i ordered a used z board on ebay .did some basic testing on it..fuses good and ipm is not shorted out....original z had open fuse and ipm tested shorted so i assume it needed a new z board..installed it today and tv still not working'
                      originally i said there was no picture in my post but actually there is a slight real grainy partial picture ...i had tv in bad location couldnt see very well when i originally started troubleshootiung......'
                      'i have taken pics with the replacement z board plugged in and without it plugged in and there isnt much difference.....any ideas??
                      the y board fuses are good and the large heat sink get hot when tv on....havent done any testing on y board since the fuse on z was bad and ipm shorted i figured thats 100% the issue...even coppell tv thought it was when i called them...
                      could the z board i bought be bad even though ipm tests not shorted and fuses ok..or is there some other multiple issue going on
                      the partial picture is very very grainy and little pinkish and the display area starts small when tv turned on and seems to get a little larger after a few minutes it like expands...but then stops ...
                      i would like to get this tv fixed if anyone can help me out...
                      the first pic is with replacement z board installed and 2nd pic with z board unplugged
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Looks like Zsus to me again. This is a reason why I always repair sustain boards than buying used ones you never know what you are getting. Possible that the ipm on the Ysus if it uses one could also be toast if there is anyway you could replace the ipm on the Ysus and possibly check the Zsus over for loose joints ect.
                        • Shinju
                          • Mar 2014
                          • 1239
                          I stopped working on these Toshiba/LG plasma panels they are spendy to repair and 9/10 times you have to replace both IPM's on y/z ect. Also you will probably need to flash the controller board to the latest firmware and that is a pain and the only person I know who has the jig to do it is CapKid.
                          These are decent picture for an old 720p plasma but if you are fixing to flip they do not sell and more then likely it's at a loss.
                          The 50" are even worse! 2 IPM's per sustain boards!
                          If you are going to replace 1 IPM I would just go ahead and do both.
                          • shelby5041
                            • Feb 2009
                            • 1505
                            thanks.......as said the fuse on z was blown and ipm tested shorted thats why i replaced z board......but since z was used....no guarantees its good.....
                            i didnt mess with y since fuses good and ipm was gettung hot when tv on
                            yes plasmas are a pain to diagnose.....and parts very costly for this model....
                            is there anythung i can test on y.....?
                            • shelby5041
                              • Feb 2009
                              • 1505
                              and if i unplug y board and leave z pkugged in i get no picture at all.......screen is 100% black
                              • ozy
                                • Jun 2009
                                • 44
                                going by the pics I would say replacement z-sus is faulty.
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  ok...also does it matter if i dont mount z board with all screws i just mounted using 2/6 screws.......for testing.......thos shouldnt affect anything right?
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    with replacement z board plugged in and y board disconnected ...i touched heat sink on z after tv on 5min...and it was cold.....is this normal?
                                    the power supply has power cables going to y and z individually so y disconnected should not affect power to z
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      and i dont have the proper equip to remove the ipms.....they are a pain....double sided board metal on both sides...and lead free solder....impossible to desolder with what i have
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        ok correction....the heat sink on replaxcement z does get warm once i have the y board connecrted also .............it stays cold is y board not connected .......anyways
                                        i ordered another used z sus..will see how what happens....i know 2 people think its a zsus issue ....since original z sus ipm was shorted and blown main fuse...it only makes sense to assume its a zsus problem
                                        however how can i be sure its not a ysus or y buffer issue?
                                        why is it so hard to troubleshott symptoms to either y or z or y buffer?
                                        just by what tv is doing and how picture is there is no way to tell which board is the issue???
                                        doesnt weach board do something specific enough to tell or do they all work together and really no way to tell ?
                                          09-06-2024, 05:27 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                          09-06-2024, 05:59 AM
