no picture on LG 37 inch tv.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys got a LG 37LH3000 LCD tv which has no picture. Backlights etc kick in no problem but no picture. Fuse on tcon tests fine.
    Tcon board part number is 6870C-0247A
    Is there any repair that can be done or would it just be a tcon replace ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: no picture on LG 37 inch tv.
    discovered this wasnt a T-Con problem. in actual fact it was a panel failure. notices a very thin 1 pixel line of white on the very top of screen moving back and forward, im guessing that was the "No Signal" trying to display.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Sure it was panel did you try a tcon ? I had on with the same issue was a as15-hf failure ???
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        yeah mate i replaced with a known working tcon and noticed a small white line bouncing along the top of screen.
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-07-2024, 07:20 AM
          09-07-2024, 07:19 AM
