lg 50pt350-ud goes on and off picture
  • mattstolte
    • Dec 2013
    • 612
    • usa
    ok have this plasma of my girlfriends and worked fine then it started picture would go out and screen be black but sound was still on and then would click back, then on and off same way but we also realized then when we had the cpu hooked up to hdmi watching movies it would freeze then play then freeze thought it would be ymain, but then with the picture freezing not sure could it be main or digital main?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: lg 50pt350-ud goes on and off picture
    any help please?
    • Hamie
      • Apr 2014
      • 1383
      Connect the 2 holes marked EXT_AUTO_GEN
      On the control board with a piece of wire, paper clip etc.
      Disconnect the LVDS cable to the mainboard.
      You will get test patterns on screen, let them cycle and see if the fault occurs.
      If it doent your mainboard is the likely culprit.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        hamie I don't have that on my main. here is what is on my main
        • mattstolte
          • Dec 2013
          • 612
          • usa
          ok it seems the picture goes on and off after it warms up alittle picture will come and go but sound will stay on, im not to sure what the little light on the tcon board is for? but t blinks then it will stay on then stay off its a little green led light. its in this picture, then I noticed the middle heatsink on the ymain is pretty warm not too warm where you cant hold your hand on it, just warm. but the tv is weird like the picture will go out stay out for a min then come back for ten then go out and such, I was wondering what that little green light is for on the tcon or digital control board
          • Hamie
            • Apr 2014
            • 1383
            You do have it you've read my post wrong.
            Control board is the small green board in the middle of the TV.
            I can see the test points in the photo you've uploaded.
            After connecting the 2 holes, disconnect the LVDS cable (the cable that connects the MAIN AV Board to the control board)
            • mattstolte
              • Dec 2013
              • 612
              • usa
              ok hamie im doing this, am I suppose to let it stop at some time or what do I do? do you mean for me to just let this keep cycling to see if the screen will cut out?
              • Hamie
                • Apr 2014
                • 1383
                Yeah if it's not affected then the mainboard is almost certainly causing your fault.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  Couldnt be ymain?
                  • Hamie
                    • Apr 2014
                    • 1383
                    If the test patterns run fine then the y-main shouldn't be the problem.
                    Possibly it's bad solder joints under the mainboards processor.
                    • mattstolte
                      • Dec 2013
                      • 612
                      • usa
                      Well got new main today that didn't fix the problem
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • CyberPhoenix
                        Issue with picture quality of Sony bravia TV
                        by CyberPhoenix
                        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                        01-22-2024, 02:08 AM
