50LGPK590 Common Problem Sound But No Video
  • omendata
    • Jun 2015
    • 25
    This is a nightmare common fault with plasmas and difficult to pin down.
    The tv just didnt come on one morning and had the usual psu relay click and standby light.
    I have repaired the psu which i thought was the issue - common problem with the two 22ohm 5 watt resistors and sometimes a diode and smps transistor on the LG PK range of televisions but the tv powers up now so I was nearly jumping for joy...until...
    Just very depressing that i also have no picture but have sound now so it seems another board on the telly caused the psu resistor to blow - incidentally its usually the top resistor but i replaced both just to be safe.
    I have tested the y-buffers today and they are fine - i bought a y sustain board off ebay and fitted it after testing the y-buffer boards were ok - it didnt fix the issue.
    Someone has said that if you pull the connection from the z-sus to the psu and you still have sound then its the z-sus board that has the fault but i dont agree with this - perhaps someone on here can confirm this as i pulled the z-sus and there is still sound indicating that z-sus board is faulty.
    Having researched for two days it seems the problem may be with the actual t-con board itself.
    I think i will bite the bullet and buy a t-con board tonight and see what happens as I am sure its not the z-sus even though the advice is that it is if you still get sound when its disconnected.
    Maybe someone more knowledgeable than i on here can give us some sort of clue.
    I really need to get an oscilloscope to fix these things properly.
    I have always got on fine with my fluke meter but for more in depth stuff like this you need and oscilloscope especially for testing the y-sus outputs.
    Someone mentioned the service port on the back of the tv that repair shops use to repair tv so i connected up an rs232 cable and can now control my television via my pc using the service port but having tried to run a self diagnostic i have found that the so called "SERVICE PORT" is not a service port at all and repair shops cannot use it to diagnose a fault its merely there to allow programming of the firmware and controlling the television unless someone know what the diagnostic command is to run a self test but i doubt it would pinpoint the issue. This also makes me pretty certain that the main board is ok and its either the z-sus or more likely the t-con board.
    You are only too old when you say you are too old!!!
  • Hamie
    • Apr 2014
    • 1383
    Re: 50LGPK590 Common Problem Sound But No Video
    Another 50pk590! These are breaking down in big numbers.
    Probably a mainboard fault.
    Read through this thread:
    • Hamie
      • Apr 2014
      • 1383
      https://www.badcaps.net/forum/showthread.php?t=47874
      • Hamie
        • Apr 2014
        • 1383
        Do the test patterns test first.
        • omendata
          • Jun 2015
          • 25
          Thanks, at last someone who knows what they are talking about.
          So this model is a bit of a lemon is it - bummer its got some great functionality and the picture isnt bad either but as with all plasmas the ridiculous y-sus system really is a pig - at least the y buffers on this model have heatsinks i have seen some really poor y-buffers with no heatsinks - should be mandatory to have a heatsink on those chips.
          Will check fully tomorrow and get back to you Hamie.
          Hopefully I can get this sorted as the nag level is at 9 (on the girlfriend-nag scale) if she cant watch Big Bang Theory in full 50 inches - what is it with size i am quite happy with my 24 inch Dell ST2220L lol
          As you are also a fellow Scot, if you help me fix this I owe you a few pints - You dont want to take a nagging girlfriend off my hands do you!
          dlol
          >;o)
          Many thanks
          Omen
          • omendata
            • Jun 2015
            • 25
            Ok couldnt wait had to check it now.
            Bridged the two connection points near P104 on the t-con board.
            I am getting no test patterns at all so I presume the T-Con is bad for sure now!
            The funny thing is that only hdmi1 is working its all i am getting sound out of - plugging the same device into hdmi2 or 3 and changing channel with the remote gets no sound so i had thought this might
            indicate a problem with the main board but i saw a youtube guy who had been struggling for weeks replacing everything on board until he tried the t-con on his 50PK590 and that fixed it.
            The main board is also getting an ip address from my home isa server via the rj45 port suggesting that its firmware is working and i can ping it fine.
            This tv has only lasted 4 years - I had a Bush old crt that lasted for 15 years and a Marconiphone that lasted for 25 years - New technology eh.
            I have learned a lesson anyway - never buy Samsung or LG should have gone for a Panasonic and not been such a tight-arse.
            I used to work for the JVC plant up in East Kilbride and all our engineers had Panasonics at home - that says a lot.
            Our JVC tellys were utterly the worst - If you ever see a JVC telly with an EK prefix - Avoid it like the plague.
            We had the monkeys on the assembly line inserting coke cans between the electrodes and loads of other stuff you wouldnt believe.
            The AIS department used to smoke dope every night during the nightshift and one guy got his finger cut off , another lost his hand - Unbelievable.
            No wonder the factory shut down especially after the main shipping manager was arrested by CID for shipping tvs out to his own customers.
            Everyone wondered why he could afford such an expensive house in Stewartfield hmmmm
            I digress however so you think the t-con could be the problem then?
            I just hope its not one of those multiple board cascading failures.#
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • slimmy182
              [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
              by slimmy182
              Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
              I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
              Looking on google I found this:...
              01-14-2023, 11:55 AM
            • mrtek
              Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
              by mrtek
              Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
              11-26-2024, 09:58 AM
