LG 50PK590 No Display
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    In regards to this post, I have tried everything. I get all voltages that matches on the panel (Vs etc)... all ok.
    The issue is, powers on, got normal power on clicks but screen remains black. No light on panel. How do I test the ysus board?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PK590 No Display
    just repaired one of these.
    On the y-sus there are 2 resistors marked VSC and -VY. What is the voltage accross them?
    Also the test points marked VZB. What's the voltage accross the 2 test points?
    • Hamie
      • Apr 2014
      • 1383
      VZB is on the z-sus
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Thanks for few pointers. I've just left work so I'll confirm tomorrow.
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          VSC: 148Vdc / 0Vac
          VY: 188Vdc / 0Vac
          Are those correct?
            That's about right.
            VZB?
            • speedypro
              • Feb 2013
              • 561
              • United Kingdom
              Originally posted by tom66
              That's about right.
              VZB?
              108.9Vdc
              Note, When TV powers on, the screen lights up then goes out in a split of a second.
              • Hamie
                • Apr 2014
                • 1383
                Check the 2 or 3 resistors on the power supply.
                If it has 2 resistors they will be 22ohm 5watt
                If it has 3 resistors the will be 10ohm 5watt.
                You can check them in circuit.
                • Hamie
                  • Apr 2014
                  • 1383
                  Resistors located top right of the supply. Close to the z-sus connector.
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    All three read 10ohms
                      Does the Vs from the power supply (around 200V) stay up or collapse after the flash? What about the other voltages, Vsc, -Vy etc.?
                      • Hamie
                        • Apr 2014
                        • 1383
                        If like Tom says all the voltages are staying up and not dropping.
                        Connect these 2 holes on the control board and disconnect the LVDS cable to the mainboard.
                        If you get test patterns on screen you have a bad mainboard.
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          Got test patterns. Well done. Thanks both of you. So main board is at fault. I'll see what's on eBay's.
                          • Hamie
                            • Apr 2014
                            • 1383
                            You will probably struggle to get a mainboard as the are scarce.
                            However you will get a mainboard for a 50pk350.
                            The board will work (I've done it)
                            But the back cover will need to be modified to fit the board as it has 2 Scart connections and only 2 HDMI.
                            If you choose this option, It will lose the netcast and HD Freeview unfortunately.
                            But last I checked the 350 mainboard are only £20.
                            • speedypro
                              • Feb 2013
                              • 561
                              • United Kingdom
                              I know. I'll dig around and consult the customer. Thanks.
                              • omendata
                                • Jun 2015
                                • 25
                                • United Kingdom
                                http://www.ebay.com/itm/LG-EBT610394...item3a82d46f8d
                                If I dont get my 50pk590 fixed you are welcome to all the parts that are working.
                                You are only too old when you say you are too old!!!
                                • speedypro
                                  • Feb 2013
                                  • 561
                                  • United Kingdom
                                  Bringing up this post again. Do you think that if I flash this tv bios, it would solve the issue? I still have not sorted this tv...I may just keep it for personal use.
                                  • sordids999
                                    • May 2013
                                    • 2155
                                    • uk
                                    Whats your main board number ?
                                    Recently stripped one these cracked screen
                                    • lgplasma350
                                      • Oct 2015
                                      • 1
                                      • uk
                                      hello. I am new to this forum, I do not know anything about tvs. as l have been reading the above this is exactly what happened to my tv. can anybody show me a picture where the main board is. My tv is LG-50pk350. I am willing to have a go at it.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        Maybe have a read of this thread too and what seems to be the problem with your set?
                                        https://www.badcaps.net/forum/showth...hlight=50PK590
