Samsung LN46C750R2F/ Sound but No Video
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung LN46C750R2F/ Sound but No Video
    I had a LN46C650 with a BN44-00341B power supply. Set had no backlight so I checked this cap and it was bad (0.2nf) but wanted to verify with another cap but didn't have the same. I couldn't decipher the markings but found a 680nf which I presumed to be the same working voltage (similar circuit location on donor board. The cap is in the pic atop the fuse and the set works fine now.
    Is there any reason I shouldn't leave this cap in, especially if the circuit itself is causing the cap to lower in capacitance over time ?
    • Kjell
      Samsung Series 9 - BIOS issue
      by Kjell
      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
      08-01-2025, 09:15 AM
      09-07-2024, 05:50 AM
    • alltvrepairs
      Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
      by alltvrepairs
      I have confirmed that I have a mainboard problem.
      I have tracked no hardware issued on board so might be a software dump required.
      I have searched a bit but wasn't able to find anything for my screen:
      Here are some more details:
      Panel: cy-nn065hgev1h
      Main: BN94-14180M P08F
      Your help much appreciated!
      05-16-2025, 03:03 AM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
    • JRade
      Audio video receiver KENWood KR-V990D,no sound
      by JRade
      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
      I replaced the capacitor C303/0.047F, nothing changes.
      I'm asking for help, what should I do next?
      Thanks in advance!...
      08-05-2025, 10:23 PM
