LG 60" 60pv250 sound but no picture
  • eliteconcept
    • 16
    Re: LG 60" 60pv250 sound but no picture
    I did a quick test, DID NOT PLUG the buffers back into the y-sus.
    The led on the control board did 3 quick flashes, and one slow flash
    • eliteconcept
      • 16
      Originally posted by Hamie
      Out of interest is the control board LED blinking once every six seconds?
      Heres what I found
      With and without the buffers plugged in to the y-sus the control board led does the same thing. 3 fast blinks and 1 slow blink.
      • Hamie
        • Apr 2014
        • 1383
        Ok I believe it should blink once every 2 seconds.
        Can you confirm one of your posts earlier you said zbias should be 110, and it only reached 1 volt? Or do you mean it reached 110 then dropped off?
        Would be strange (but not impossible) for both the y-sus and z-sus to both be faulty considering they are separately linked through the power supply.
          Hamie... isn't that just for Samsung sets?
          I think the LG LED is only blinking according to panel temperature in some kind of morse-like scheme.
          • eliteconcept
            • 16
            I tested again both with having the leads right on the test point when the tv is turned on and after it is turned on. in both cases the reading started off at or around 0 then slowly ramped up to about 1.
            • eliteconcept
              • 16
              #26
              Does this mean that both ysus and zsus are bad?
              • MVC
                • Jul 2015
                • 33
                My 60PV450is same basic set. And it now seems that both Y & Z Sustain boards are bad.
                I have come to the conclusion that these sets were right on the edge, a little push and down they go.
                • Bad60pv250
                  • Sep 2016
                  My lg 60pv250 just lost picture but has sound trying to figure it out aswell i orderd a new powerboard thinking that would fix it but the board i received via ups was cracked. And now im back at step one any suggestions?
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • jchang
                    Samsung UN70NU6900F no picture and no sound
                    by jchang
                    Hi all
                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                    Symptom:
                    No picture no sound.
                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                    No sound at all.
                    What I tried:
                    1. I tried unplugging the left or right ribbon...
                    01-09-2023, 06:28 PM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
