Panasonic TC-P55ST30 SNAFU'ed, SC board blown, I think...
  • Terryfictv
    • Mar 2011
    • 124
    Re: Panasonic TC-P55ST30 SNAFU'ed, SC board blown, I think...
    Thanks .....a good report is coming soon !
    • MTWallet
      • Jul 2015
      • 14
      Got everything re-installed last night after testing the SC41, SC42 & SC46 connectors as well as the flexi-cables that attach to the SU/SD boards. Also did the isolation test with SC50 jumpered. Nothing seemed amiss, so I plugged it all in proper and gave it a go... SUCCESS!! TV came on and displayed properly, thanks to Terryfictv, tw2005 and flocko for your assistance. I remounted the heatsinks with thermal tape and silicone, as well as adding sinks to the other three transistors that did not have them. Time will tell if the repair holds, but seems to have been the fix for now. Testing the transistors on the bench showed three of them to be trashed. The diodes were good and the other three trans did not show shorted tab to pins 1 or 3. I'll keep them as spares for possible future use. Thanks again all!
      • Terryfictv
        • Mar 2011
        • 124
        Awesome! Well done, MTWallet. See you next time!
        • MTWallet
          • Jul 2015
          • 14
          Well, unfortunately the repair didn't hold. After a few more hours on the TV, there was a nice sharp pop last night, and back to solid red LED, or 14 blinks if you hold down the power button. I will tear it down again and see what's up. If its the SC board again or something else.
          • Terryfictv
            • Mar 2011
            • 124
            The diodes in the circuit that is blown should be replaced in case they were stress damaged. Also, did you change the mounting hardware and clean ground connects of black hi resistance junk ? ( use tool or scrape with razor blade ? ) Did you snug the mounting screws tight ? Did you confirm SS board has no shorted parts by test not by guess ?
            Terry
            • MTWallet
              • Jul 2015
              • 14
              Two diodes and 6 transistors were replaced, that is what was in the kit. Used new mounting hardware which had the lock-washers on them. I used a fiberglass pen brush to clean the ground contacts where the screws attached the board to the main chassis of the TV. The only thing done with SS board was to confirm that after SS11 was disconnected, that there was no direct short on that connector at the SS board.
              • SnapTech
                • Sep 2015
                • 9
                Check Q600. If it's bad your IGBT's will blow again. Also check R608. If it reads much lower than 15K ohms, Q600 is bad.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                  After all of...
                  07-13-2024, 08:14 PM
                • canadaboy25
                  Panasonic TC-P54VT25 No image. A or D board?
                  by canadaboy25
                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                  01-17-2021, 01:06 AM
                • stecos
                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                  by stecos
                  Hi everyone!
                  I happened several times, in the search for help from the web, to consult this very interesting forum.
                  So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                  Having said that I come to the gist of my post on the forum as the title suggests.
                  For my passion for technology I'm now collecting several...
                  11-28-2022, 11:39 AM
