xenius LCDX32WHD88 (B) Backlight problem
  • Kevan02
    • Jun 2015
    • 8
    • United Kingdom
    Hi
    First i need to say my knowledge is very basic but have been researching the net to
    fix my problem which follows
    The tv when plugged in light's up to standby but when i try to switch it on the
    backlight lights up for a few seconds then goes out. The tv is on as i get sound
    and can see the picture on the screen if i shine a light on it. Having researched
    the problem it seemed it was a inverter board problem so bought a replacement
    inverter board) at same time noticed that their was a few bad caps on the power board
    so replaced that as well hoping it would fix the problem but it still shut's down after
    a few secs.
    With my increased frustration i researched more that led me to the light test beside the
    transformers and output leads and they all light up the bulb i also striped the tv down
    to check for bad bulbs inside the tv but they all light up for a few secs when the tv
    is switched on.
    So all that has brought me here to ask for help as i don't know where to go next with the TV
    Thx Kev
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: xenius LCDX32WHD88 (B) Backlight problem
    first you have to post some pictures
    • ammarben
      • May 2013
      • 63
      • algeria
      second do some mesurment voltage of all connectors with ther labels
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        We need photos of all the boards and how they are connected please.
        • Kevan02
          • Jun 2015
          • 8
          • United Kingdom
          Sorry took so long but here are the pic's
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok do you have a digital muiltimeter to be able to test the voltage thats the psu gives out ?
              Pictures really need to be clearer - more light and higher resolution. If your camera can't do high resolution, take multiple photos that we can look at separately.
                Need better pictures of the Inverter board, especially around the connector so we can see the name of the pins. It is made by CMO, can you read the P/N of this imverter board?
                • Kevan02
                  • Jun 2015
                  • 8
                  • United Kingdom
                  Here are some better/closer pics, and i have a multimeter but will need some direction on specific parts to test please.
                  Thx Kev
                  Oh this is all the info from sticker's on other side of inverter -:
                  Sticker 1
                  K$27 - D028708 - L$AHX915807D701A
                  I315B3 - 6UA - A401A
                  Sticker 2
                  27 - D028708
                  T87I029. 19 LF
                  E400003296 - 01L1
                  • Kevan02
                    • Jun 2015
                    • 8
                    • United Kingdom
                    Could somebody let me know if the above pic's are ok please and sorry if Y'all busy
                      https://www.badcaps.net/forum/attach...2&d=1436562696
                      The last 3 pins are the command signals form main board.
                      You have BL_ON (Backlights ON, >2.5VDC steady = ON)
                      I_PWM: Internal PWM DIMMING Control
                      E_PWM: External Dimming Control.
                      So what DCV do you have on all those 3 pins with ref to the chassis GND? Do you have steady 24VDC from power supply to run the inverter?
                      • Kevan02
                        • Jun 2015
                        • 8
                        • United Kingdom
                        i am getting 24.3 on all 3 pin's continuous when i put tv on from standby. when in standby 00.03
                          That cannot be, those signals pin are 5V level, if you have 24VDC on all those 3 pins you have bigger problems.
                          Are you sure you look at the last 3 pins on the right side of the connector? What did you use for GND ref. for the meter?
                          • Kevan02
                            • Jun 2015
                            • 8
                            • United Kingdom
                            Sorry was looking at wrong side to my total embarrassment. I am using the T.V metal frame for ground and on the correct pin's it reads -
                            3rd from last 03.16 continuous
                            2nd from last 03.28 continuous
                            last 02.53 continuous
                            when tv is on
                              OK, they are all good.
                              Transformers testing will be the next step.
                              • Kevan02
                                • Jun 2015
                                • 8
                                • United Kingdom
                                Was wondering if somebody could point me to anywhere i can get some instruction on testing the Transformers.
                                Thx
                                • Dobrowol
                                  Asus GA402RK keyboard and kb backlight problem
                                  by Dobrowol
                                  Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                  04-28-2025, 04:30 PM
                                • ononos
                                  LG M2362DP Backlight problem
                                  by ononos
                                  hello everyone!
                                  As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                                  I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                                  So i decided to try to...
                                  03-12-2023, 05:05 AM
                                • fanaticgames
                                  Samsung UE32D4010 Backlight problem, led ok
                                  by fanaticgames
                                  hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                  02-22-2023, 09:46 AM
                                • Honziq
                                  Backlight problem - Asus M3200WU, board Gapal LA-L291p
                                  by Honziq
                                  I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                                  I was repaired many backlights before but this design i will not understand.
                                  For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                                  Can someone explain me please what to do, what to check?
                                  Thanks....
                                  11-20-2024, 01:24 PM
                                • grbo92
                                  Backlight problem Acer LA-031P
                                  by grbo92
                                  i have one acer Nitro 5 without backlight on my desk.
                                  Mainboard model: LA-L031P GH53Z REV 1B
                                  Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                                  11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                                  Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                                  Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                                  09-09-2024, 03:49 AM
