xenius LCDX32WHD88 (B) Backlight problem
+ More Options
Posts
  • Kevan02
    • Jun 2015
    • 8
    • United Kingdom
    Hi
    First i need to say my knowledge is very basic but have been researching the net to
    fix my problem which follows
    The tv when plugged in light's up to standby but when i try to switch it on the
    backlight lights up for a few seconds then goes out. The tv is on as i get sound
    and can see the picture on the screen if i shine a light on it. Having researched
    the problem it seemed it was a inverter board problem so bought a replacement
    inverter board) at same time noticed that their was a few bad caps on the power board
    so replaced that as well hoping it would fix the problem but it still shut's down after
    a few secs.
    With my increased frustration i researched more that led me to the light test beside the
    transformers and output leads and they all light up the bulb i also striped the tv down
    to check for bad bulbs inside the tv but they all light up for a few secs when the tv
    is switched on.
    So all that has brought me here to ask for help as i don't know where to go next with the TV
    Thx Kev
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: xenius LCDX32WHD88 (B) Backlight problem
    first you have to post some pictures
    • ammarben
      • May 2013
      • 63
      • algeria
      second do some mesurment voltage of all connectors with ther labels
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        We need photos of all the boards and how they are connected please.
        • Kevan02
          • Jun 2015
          • 8
          • United Kingdom
          Sorry took so long but here are the pic's
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok do you have a digital muiltimeter to be able to test the voltage thats the psu gives out ?
              Pictures really need to be clearer - more light and higher resolution. If your camera can't do high resolution, take multiple photos that we can look at separately.
                Need better pictures of the Inverter board, especially around the connector so we can see the name of the pins. It is made by CMO, can you read the P/N of this imverter board?
                • Kevan02
                  • Jun 2015
                  • 8
                  • United Kingdom
                  Here are some better/closer pics, and i have a multimeter but will need some direction on specific parts to test please.
                  Thx Kev
                  Oh this is all the info from sticker's on other side of inverter -:
                  Sticker 1
                  K$27 - D028708 - L$AHX915807D701A
                  I315B3 - 6UA - A401A
                  Sticker 2
                  27 - D028708
                  T87I029. 19 LF
                  E400003296 - 01L1
                  • Kevan02
                    • Jun 2015
                    • 8
                    • United Kingdom
                    Could somebody let me know if the above pic's are ok please and sorry if Y'all busy
                      https://www.badcaps.net/forum/attach...2&d=1436562696
                      The last 3 pins are the command signals form main board.
                      You have BL_ON (Backlights ON, >2.5VDC steady = ON)
                      I_PWM: Internal PWM DIMMING Control
                      E_PWM: External Dimming Control.
                      So what DCV do you have on all those 3 pins with ref to the chassis GND? Do you have steady 24VDC from power supply to run the inverter?
                      • Kevan02
                        • Jun 2015
                        • 8
                        • United Kingdom
                        i am getting 24.3 on all 3 pin's continuous when i put tv on from standby. when in standby 00.03
                          That cannot be, those signals pin are 5V level, if you have 24VDC on all those 3 pins you have bigger problems.
                          Are you sure you look at the last 3 pins on the right side of the connector? What did you use for GND ref. for the meter?
                          • Kevan02
                            • Jun 2015
                            • 8
                            • United Kingdom
                            Sorry was looking at wrong side to my total embarrassment. I am using the T.V metal frame for ground and on the correct pin's it reads -
                            3rd from last 03.16 continuous
                            2nd from last 03.28 continuous
                            last 02.53 continuous
                            when tv is on
                              OK, they are all good.
                              Transformers testing will be the next step.
                              • Kevan02
                                • Jun 2015
                                • 8
                                • United Kingdom
                                Was wondering if somebody could point me to anywhere i can get some instruction on testing the Transformers.
                                Thx
                                • theone111
                                  by theone111
                                  3. Problem: TV shuts down
                                  07-22-2024, 10:36 AM
                                • Zeonalbasta
                                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                  by Zeonalbasta
                                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                  09-13-2024, 01:17 PM
                                • Gibon378
                                  Problem with stopping audio and video for no reason
                                  by Gibon378
                                  PC Specs:
                                  • CPU: Ryzen 5 1600
                                  • GPU: GTX 1080 Palit JetStream
                                  • MOBO: ASRock ab350 PRO4
                                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                  • PSU: XFX 650W (don't remember what model)
                                  • OS SSD: ADATA SP920
                                  • OS: Windows 10 21H2
                                  Problem description:
                                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                  11-19-2022, 09:41 AM
                                • perzyk23
                                  Lenovo T580 - LCD Panel problem - error 0288
                                  by perzyk23
                                  Good morning,
                                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                  10-25-2024, 12:42 AM
                                • SDNarcia
                                  Dell 15R-5521 keyboard problem (KBC?)
                                  by SDNarcia
                                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                  As additional information,...
                                  07-20-2024, 10:47 PM
