LG 60pv250-tb ..Z sus issue
  • DanDontknow
    • Jul 2015
    • 9
    • australia
    Hello I have a 60" Plasma Lg
    The Screen is purple and slow to get the picture when turned on
    I started searching this site and have found a lot of useful information
    I removed the z sus board and fixed the broken solder joints on the coils.
    I checked the powers as per the sticker
    I checked the fuses on the boards and found high o/c on the vs for the Z sus
    I replaced the fuse and now it wont turn on.
    I removed the cables to the z sus board and the control board boots up
    so I removed the fuse and I still have the original problem.
    I am guessing control board wont boot because there is a further problem with the the Z sus board ( the fuse for the VS has not blown again.)
    I have tried looking for the board online and its not as easy or as cheap to find as I had hoped. I would like to repair the board if possible.
    Where should I begin.
    Thanks Dan
  • sordids999
    • May 2013
    • 2161
    Re: LG 60pv250-tb ..Z sus issue
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      You'll need to pull the Z and check all the IGBT's etc for shorts.
      You'll probably find 4 to 8 of them short and possibly some diodes and maybe the driver chips too....
      TELEFIX
      • DanDontknow
        • Jul 2015
        • 9
        • australia
        Thanks for the replys, Is there anyway to read the control board to find out what is stopping it from booting or should I just start checking everything on the z sus board.
        Cheers Dan
        • DanDontknow
          • Jul 2015
          • 9
          • australia
          Picture of the Z Sustain board as viewed from the back of the tv fitted to the top right.
          The fuse holder I fitted is for ease as removal only
          • DanDontknow
            • Jul 2015
            • 9
            • australia
            Picture of the Z Sustain board .
            Rear of board--Imaged flipped to match circuits easier on pics
            • DanDontknow
              • Jul 2015
              • 9
              • australia
              I will be playing with the board tomorrow
              Does anyone know if I can isolate different parts of the board by removing the least amount of components to check for shorts.
              or the most likely section to start with for a short on the vs power
              which igbt to remove first.
              Thanks Dan
                You would want to focus on removing the IGBTs in the SUS path - the ones connected to Vs or GND. A Z-sus only has one bias path (the Vzb section) - that's probably OK - it's usually formed of two back-to-back MOSFETs. There's also an energy recovery section which is also probably OK.
                • DanDontknow
                  • Jul 2015
                  • 9
                  • australia
                  Thanks Tom
                  • DanDontknow
                    • Jul 2015
                    • 9
                    • australia
                    Update
                    I have de-soldered the IGBTs and found 4 shorted
                    I have checked the board now
                    what would be the acceptable ohms reading between the ground and the Z sus path
                    I have
                    144kohms between ground and the fuse
                    670kohms between ground and the 3 plugs on the right.
                      That looks OK to me
                      • DanDontknow
                        • Jul 2015
                        • 9
                        • australia
                        Thats good to here.
                        Looking online for the IGBTs FGPF4633
                        I can find some from china on ebay but not sure I would trust them.
                        or locally would any of these match
                        http://www.altronics.com.au/electron...ation_2=mosfet
                        http://www.jaycar.com.au/search?q=fe...211C&text=fets
                        These stores are similar to maplins
                        if not where is the best place to order from.
                        Thanks Dan
                        • bruceleeworldwide
                          • Aug 2016
                          • 4
                          • australia
                          Hi, Alastair E
                          This is very good information, I read it thoroughly but I could not get clear still. For example, there are 5 voltages on y board of lg60pv250, +Vsustain, Vsc, V-xy, Vset up, Vset down while there are only 3 (+Vsustain, +Vset, -Vreset) in Figures . Can you pls tell me more how to match them? I am interested in it. …Why isn't there the Vscan?
                          Thank you.
                          Bruce
                          • Soulzink
                            Samsug washing machine. Power supply DC41-00189a board issue
                            by Soulzink
                            I am trying to fix a samsung washinmachine power supply main board.
                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                            The power supply board reference is the following: DC41-00189a
                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                            04-19-2025, 06:26 AM
                          • Yanleb
                            LG 60PK550 Logic Control Board EBR63450301
                            by Yanleb
                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                            C57: 3.30V
                            C61:...
                            07-20-2023, 12:38 AM
                          • joliver82
                            Sony XR-65A95L no power due to logic board issue
                            by joliver82
                            Hi guys!
                            I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
                            First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
                            When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
                            Today, 04:57 PM
                          • Asraf Atb
                            by Asraf Atb
                            01-27-2025, 05:02 PM
                          • Stephen
                            A2991 Logic Board issue, 20volts 0 amps help!
                            by Stephen
                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                            09-10-2025, 03:16 PM
