Panasonic TH-42PZ77U Noise
  • Rockguy
    • Jan 2015
    • 71
    This TV just started to make an annoying noise with the audio. During quiet passages, there is no noise. It's not a constant thing. It's like distortion in the voices. Has anything like this been brought up around here?
  • Rockguy
    • Jan 2015
    • 71
    Re: Panasonic TH-42PZ77U Noise
    v
    • Rockguy
      • Jan 2015
      • 71
      I made a video so hopefully it helps figure this out. It's annoying to watch the set like this.
      http://vid82.photobucket.com/albums/...psq0ocodh7.mp4
      • Rockguy
        • Jan 2015
        • 71
        I always believe in following up. It turns out it was my Directv receivers HDMI output making the noise. The TV was not at fault at all. I fixed it by doing a hard reset of the receiver. Another thing to put in my memory bank.
        • tony359
          by tony359
          11-28-2023, 05:18 AM
        • MegaZAC
          Onkyo TX-SR805 noise in one channel
          by MegaZAC
          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
          There's some logic behind it. As soon as I select an input I get only left...
          04-23-2025, 10:09 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
