Samsung UE50ES5505 double image
  • PowerAmpFreak
    • 982
    • Sweden
    Samsung LED model UE50ES5505 goes suddenly into double image mode.
    it appears there is some failure around T-CON / ribbon wiring to panel. Please advice.
    When both panel ribbons are seated double image begin.
    When the left ribbon is unmounted, the right part of the picture is nice and stable.
    But not other way around.
    bad T-con? bad ribbons? bad panel?
    Re: Samsung UE50ES5505 double image
    Bad panel, I'll say.
    • waii8
      • Jun 2015
      • bahrain
      please chang your lcd stips
      • PowerAmpFreak
        • 982
        • Sweden
        Do you mean the 2 ribbons between T-con and panel?
        Why does the screen be Ok when remove one of them? (half screen OK and no double image) ?
        • ammarben
          • May 2013
          • 63
          • algeria
          LED LCD TV FIX, How To For Samsung Double Image
          https://www.youtube.com/watch?v=j7vl7-vZEL8
          • PowerAmpFreak
            • 982
            • Sweden
            I try to find two new ribbons for this one.
            Did not have any luck with the tape trick.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Try taking the original strips and clean them then use a cotton swab soaked with WD-40 and moisten the fingers. Refit and see if that helps. I had a similar problem and in desperation tried this trick and it worked. The 'dry joint' syndrome.
              • saddle_au
                Waste Warrior
                • 121
                Remove the strips one at a time and work out which side the fault originates on. Clean the strip (white rubber) and the contacts on the boards (folded white paper run like sand paper on the contacts). Blow out any fibers, try it again.
                If the problem persists, I have had luck with removing some contacts points curing this (heaven knows why this works). This is what they are doing in the videos. You are stopping one or two cables working between the tcon and the panel. Use a small bit of tape covering about two pins and try this, working your way along the ribbon from the outside edge in starting about 3 pins in from the outer edge. Put it in, turn it on, look to see if there is a change. If not turn off, move it along a pin and try again. Seems to work somewhere in the first half of the panel ribbon cable.
                • BigPete
                  • Jul 2012
                  • 69
                  • New Zealand
                  Thanks ammarben.
                  I had a double image on a Samsung LA40D550 and your link fixed the TV.
                  I had doubts if it would work. I'm not sure why it works.
                  I posted a pic of what I did.
                  Is it possible that part of the ribbon cable is panel feedback and gives the T-Con board wrong info.
                  • Cornito
                    Samsung UE55RU8000 reboot and then double image after heating up
                    by Cornito
                    Hello team,
                    I'm back with another tv and another problem.
                    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                    First, reboot issue, I use tape Method to find out the right side that cases the issue.
                    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                    Then double image reduce in height and move to the top.
                    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                    When I...
                    03-31-2024, 01:37 PM
                    09-07-2024, 05:50 AM
                  • howardc64
                    TCL 49S405 double image
                    by howardc64
                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                    06-23-2025, 03:20 PM
                  • shlomim412
                    samsung ua55es6800 - no image
                    by shlomim412
                    hi
                    having problem with samsung ua55es6800
                    tv had backlight on, sound working - responds to the remote control but no image.
                    check tcon board - had 12v in but no other voltages present.
                    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                    when leaving only left side connected - again no voltages and no image.
                    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                    kept trying to block less pins on the left ribbon cable...
                    05-15-2024, 05:00 AM
                    09-06-2024, 11:40 PM
