SONY KLV-32EX400 No Power No LED on
    After Power fluctuation my lcd stop working.
    I open the lcd, it have Power Board G2LE.
    I measure the voltage at connector CN6401
    Pin - DC Volt
    1 = 3.28v
    2 = 3.28v
    3 = 3.22v not changed when press on/off button
    4 = 12.65v
    5 = 0v
    6 = 0v
    7 = 0v
    8 = 12.65v
    9 = 12.65v
    10 = 0.15v
    11 = 0v
    12 = 0v
    13 = NC
    14 = 0v
    15 = 0v
    Help in this regard, so that i on my lcd.
    Re: SONY KLV-32EX400 No Power No LED on
    No pin names to tell us what those pins are?
      Pin - Function - Measure DC Volt
      1 = Standby - 3.28v
      2 = AC Off Det - 3.28v
      3 = Power On - 3.22v not changed when press on/off button
      4 = Audio 12v - 12.65v
      5 = Audio 12v GND - 0v
      6 = Reg12v GND - 0v
      7 = Reg12v GND - 0v
      8 = REG12V - 12.65v
      9 = REG12V - 12.65v
      10 = BL-ERR - 0.15v
      11 = BL-On - 0v
      12 = Dimmer - 0v
      13 = NC
      14 = T-con-VCC 12v - 0v
      15 = T-CON-ON - 0v
        please write more detail. standby red led is on? or power on green led is on.
        any fleshing red led ?
        audio on?
        11 = BL-On - 0v = no backlight.
        you write at first post. 14 = 0v
        now 14 = T-con-VCC 12v - 0v
        15 = T-CON-ON - 0v
        if tcon on volt is 0v. it is not possible to output T-con-VCC 12v - 0v.
        you can check backlight on by 100R res. make jumper Pin 1 to pin 11 for check backlight on.
        wbr
          No Standby Red LED on, No Power on Green LED on, no LED Flashing.
          Pin No. is 14 = Pin Function is T-con-VCC 12v - and i measure 0v on it.
            disconnect lvds cable from main board ( Not from tcon side.) and check again. also check backlight on by 100r resister jumper from pin 1 to pin 11.
              Follow instructions anmol Post# 6 and tell what you see.
                G2le
                  Remove connector from Main Board. Place resistance 100R from 1 to 11 No. pin.
                  Back light turns on.
                    OK. So now we may have a Main Board issue.
                      No blinking codes?
                      So far the main board is not sending the
                      11 = BL-On - 0v
                      12 = Dimmer - 0v
                      15 = T-CON-ON - 0v
                      So your main board is not functioning.
                        On Main board (BAA1A), Where should i check the proper supply of Micro controller etc.
                        if possible with picture, please.
                        any one have service manual & Schematic of Main Board please also post.
                          Try this site:
                          http://elektrotanya.com/?q=showresul...at2=schematics
                            Where should i purchase Main board (BAA1A), guide please.
                              I have the same board for Sony LCD (KLV-26EX300) TV BAA1A (A-1768-177-B 1047687) and G1LSE Power board. Ihave Same issue from the power board i get only 3.3v Standby
                              same as this thread.
                              1 = Standby - 3.28v
                              6 = Reg12v GND - 0v
                              7 = Reg12v GND - 0v
                              8 = REG12V - 12.65v
                              9 = REG12V - 12.65v
                              10 = BL-ERR - 0.15v
                              11 = BL-On - 0v
                              12 = Dimmer - 0v
                              13 = NC
                              15 = T-CON-ON - 0v
                              Tried mentioning BL ON through sorting Pin 1 to Pin 11 using 100 Ohm resistor. but BL not on.
                                audio on?
                                15 = T-CON-ON - 0v
                                wbr
                                1 = Standby - 3.28v
                                6 = Reg12v GND - 0v
                                7 = Reg12v GND - 0v
                                8 = REG12V - 12.65v
                                9 = REG12V - 12.65v
                                10 = BL-ERR - 0.15v
                                11 = BL-On - 0v
                                12 = Dimmer - 0v
                                13 = NC
                                15 = T-CON-ON - 0v
                                Tried mentioning BL ON through sorting Pin 1 to Pin 11 using 100 Ohm resistor. but Back light not on.
                                Standby indicator not on (Green or Red).
                                  Try it again with about a 1k resistor.
                                    Check the fuse on the inverter board.
                                      What is the voltage at Pin3 (Power_On) when the mainboard is disconnected from the power supply?
                                        1 = Standby - 3.28v
                                        6 = Reg12v GND - 0v
                                        7 = Reg12v GND - 0v
                                        8 = REG12V - 12.65v
                                        9 = REG12V - 12.65v
                                        10 = BL-ERR - 0.15v
                                        11 = BL-On - 0v bad
                                        12 = Dimmer - 0v bad
                                        13 = NC
                                        15 = T-CON-ON - 0v bad
                                        You said you only get 3.3V Standby but the chart shows Voltages on other pins also.
                                        Also show us pictures of the whole backside of the TV showing all the boards.
