SONY KLV-32EX400 No Power No LED on
  • masoodlodhran
    Old is Gold
    • Jun 2015
    • 9
    • Pakistan
    After Power fluctuation my lcd stop working.
    I open the lcd, it have Power Board G2LE.
    I measure the voltage at connector CN6401
    Pin - DC Volt
    1 = 3.28v
    2 = 3.28v
    3 = 3.22v not changed when press on/off button
    4 = 12.65v
    5 = 0v
    6 = 0v
    7 = 0v
    8 = 12.65v
    9 = 12.65v
    10 = 0.15v
    11 = 0v
    12 = 0v
    13 = NC
    14 = 0v
    15 = 0v
    Help in this regard, so that i on my lcd.
    Re: SONY KLV-32EX400 No Power No LED on
    No pin names to tell us what those pins are?
    • masoodlodhran
      Old is Gold
      • Jun 2015
      • 9
      • Pakistan
      Pin - Function - Measure DC Volt
      1 = Standby - 3.28v
      2 = AC Off Det - 3.28v
      3 = Power On - 3.22v not changed when press on/off button
      4 = Audio 12v - 12.65v
      5 = Audio 12v GND - 0v
      6 = Reg12v GND - 0v
      7 = Reg12v GND - 0v
      8 = REG12V - 12.65v
      9 = REG12V - 12.65v
      10 = BL-ERR - 0.15v
      11 = BL-On - 0v
      12 = Dimmer - 0v
      13 = NC
      14 = T-con-VCC 12v - 0v
      15 = T-CON-ON - 0v
      • anmol
        • Mar 2012
        • 73
        • India
        please write more detail. standby red led is on? or power on green led is on.
        any fleshing red led ?
        audio on?
        11 = BL-On - 0v = no backlight.
        you write at first post. 14 = 0v
        now 14 = T-con-VCC 12v - 0v
        15 = T-CON-ON - 0v
        if tcon on volt is 0v. it is not possible to output T-con-VCC 12v - 0v.
        you can check backlight on by 100R res. make jumper Pin 1 to pin 11 for check backlight on.
        wbr
        • masoodlodhran
          Old is Gold
          • Jun 2015
          • 9
          • Pakistan
          No Standby Red LED on, No Power on Green LED on, no LED Flashing.
          Pin No. is 14 = Pin Function is T-con-VCC 12v - and i measure 0v on it.
          • anmol
            • Mar 2012
            • 73
            • India
            disconnect lvds cable from main board ( Not from tcon side.) and check again. also check backlight on by 100r resister jumper from pin 1 to pin 11.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Follow instructions anmol Post# 6 and tell what you see.
                G2le
                • masoodlodhran
                  Old is Gold
                  • Jun 2015
                  • 9
                  • Pakistan
                  Remove connector from Main Board. Place resistance 100R from 1 to 11 No. pin.
                  Back light turns on.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    OK. So now we may have a Main Board issue.
                      No blinking codes?
                      So far the main board is not sending the
                      11 = BL-On - 0v
                      12 = Dimmer - 0v
                      15 = T-CON-ON - 0v
                      So your main board is not functioning.
                      • masoodlodhran
                        Old is Gold
                        • Jun 2015
                        • 9
                        • Pakistan
                        On Main board (BAA1A), Where should i check the proper supply of Micro controller etc.
                        if possible with picture, please.
                        any one have service manual & Schematic of Main Board please also post.
                          Try this site:
                          http://elektrotanya.com/?q=showresul...at2=schematics
                          • masoodlodhran
                            Old is Gold
                            • Jun 2015
                            • 9
                            • Pakistan
                            Where should i purchase Main board (BAA1A), guide please.
                            • Herry Patel
                              • May 2020
                              • India
                              I have the same board for Sony LCD (KLV-26EX300) TV BAA1A (A-1768-177-B 1047687) and G1LSE Power board. Ihave Same issue from the power board i get only 3.3v Standby
                              same as this thread.
                              1 = Standby - 3.28v
                              6 = Reg12v GND - 0v
                              7 = Reg12v GND - 0v
                              8 = REG12V - 12.65v
                              9 = REG12V - 12.65v
                              10 = BL-ERR - 0.15v
                              11 = BL-On - 0v
                              12 = Dimmer - 0v
                              13 = NC
                              15 = T-CON-ON - 0v
                              Tried mentioning BL ON through sorting Pin 1 to Pin 11 using 100 Ohm resistor. but BL not on.
                              • Herry Patel
                                • May 2020
                                • India
                                audio on?
                                15 = T-CON-ON - 0v
                                wbr
                                1 = Standby - 3.28v
                                6 = Reg12v GND - 0v
                                7 = Reg12v GND - 0v
                                8 = REG12V - 12.65v
                                9 = REG12V - 12.65v
                                10 = BL-ERR - 0.15v
                                11 = BL-On - 0v
                                12 = Dimmer - 0v
                                13 = NC
                                15 = T-CON-ON - 0v
                                Tried mentioning BL ON through sorting Pin 1 to Pin 11 using 100 Ohm resistor. but Back light not on.
                                Standby indicator not on (Green or Red).
                                • nomoresonys
                                  • 12145
                                  • U.S.
                                  Try it again with about a 1k resistor.
                                  • nomoresonys
                                    • 12145
                                    • U.S.
                                    Check the fuse on the inverter board.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      What is the voltage at Pin3 (Power_On) when the mainboard is disconnected from the power supply?
                                        1 = Standby - 3.28v
                                        6 = Reg12v GND - 0v
                                        7 = Reg12v GND - 0v
                                        8 = REG12V - 12.65v
                                        9 = REG12V - 12.65v
                                        10 = BL-ERR - 0.15v
                                        11 = BL-On - 0v bad
                                        12 = Dimmer - 0v bad
                                        13 = NC
                                        15 = T-CON-ON - 0v bad
                                        You said you only get 3.3V Standby but the chart shows Voltages on other pins also.
                                        Also show us pictures of the whole backside of the TV showing all the boards.
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                          Acer Aspire A515-55-322V Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-55-322V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-55-322V boardview and A515-55-322V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 10:50 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
