Hi there, I'm trying to fix a Vizio p50hdtv10a plasma tv that has a very dark picture. I tested the boards with my multimeter and found out that one of the IPM modules on the z-sustain board has shorted out. I sacrificed the part by breaking the pins loose with a small flat head screw driver. I was able to get most of the pins out using some small tweezers and a 30W soldering iron. However, some of the pins are really stuck in the holes and I couldn't remove them with my iron. I tried adding solder the the pins but that didn't work. Is there another way I can remove these stuck pins without damaging the board with too much heat? Any help would be greatly appreciated.
					Trying to remove stuck IPM pins
	Tags: None
 Re: Trying to remove stuck IPM pins
 Get yourself some of this stuff.
 http://www.chipquik.com/store/produc...ucts_id=210001
 And the cheapest place to order from is here if you have prime shipping.
 http://www.amazon.com/ChipQuik-SMD1-...words=chipquik
 I started to use it a while back and I have removed several of these IPM's I am working on the same TV you have listed right now.
 I have a JBC soldering & Desoldering station and also a Hot Air station and as far as I am concerned this stuff is worth the money not to damage the board.
 I can remove the IPM with out damaging the board or the IPM NO BREAKING pins! and I bet that even the 30W iron you have might still get the job done.
 Hope this helps!Last edited by dolivas27; 06-22-2015, 06:13 PM.
 Yes it does I add it to the pin's with a soldering iron and use the hot air station to keep it molten.
 You can also do it with the solder iron but you have to keep heating the pins. He stated he had already broken the pins off so this would work EXCELLENT for him.
 I have also used this before I purchase the hot air station.
 http://www.amazon.com/Weller-6966C-W...ungar+heat+gun
 When I worked for Ameritech 15 or so years ago I opened the first Motorola cell phone repair center in Michigan and this was the tool they used at Motorola and what we were trained to use. (Before hot air station became affordable)Comment
 Well I don't know about magic tricks but mine is 18 years old an still going strong and it used to be use all day long.
 But it's probably not built like it used to be plus mine says Ungar on it not Weller I think Weller purchased Unger several years ago.Comment
 I advise against purchasing expensive equipment to remove IPMs (chipquick is also ridiculously expensive for what it is).
 There's a very simple and inexpensive way of doing it:
 https://www.youtube.com/watch?v=dIEETsXWUkMComment
 I actually removed it using the method in the video, however I am having trouble removing some of the broken pins from the board. They seem to be really stuck in the holes. So far, it is suggested to use chip quik.I advise against purchasing expensive equipment to remove IPMs (chipquick is also ridiculously expensive for what it is).
 https://www.youtube.com/watch?v=dIEETsXWUkMLast edited by martinez74; 06-23-2015, 12:36 PM.Comment
 I've used the chip quick stuff before, it works really well. It is on the expenisive side for no more of it than you get, the good news is, it's like Brylcreem, "Just a little dab'll do ya!" You just need enough of there to stay molten long enough to do what you're wanting to do.Comment
 Using a hammer and screwdriver is just crazy......... Do it right or don't do it!
 Yes chip quick is more expensive than it should be but like DesertRat stated you don't need a lot and I am cheep so I reuse the stuff once the IPM is off just use your iron to pool it up in a ball and reuse later.....
 Try removing a HDMI connector off an Onkyo HDMI board even with hot air your going to ruin the HDMI board with a little chip quick I have removed and repaired several boards.
 Ruin / Save one board and chip quick has paid for itself.
 To each is to own but like I said I will never not have it on the bench to be used when needed.
 I never recommended purchasing expensive equipment! I was just stating what I have and I make money with my tools so I tend to purchase the best the first time. Cry once or bitch for the rest of your life how a tool does not work right.
 Plus I always look at it this way if you never try anything new how will you know what works and what doesn't.
 If you do use the Chip Quick please post what you think of it.
 Talk to you soon......Last edited by dolivas27; 06-23-2015, 10:40 PM.Comment
 Yes, but does chipquick give you enough time, considering the amount of pins on the IPM?
 I would also imagine that you would have to clear away as much as the tin solder as possible so as not to adulterate the chipquick alloy.
 And then you would also have to make sure to remove as much chipquick solder as possible, because if it mixes with the fresh solder, it will make it brittle.Comment
 If I get some time I will do a video so you can see it in action.
 Yes I do add some solder and then remove it with the desoldering station or solder wick.
 Yes it would make it brittle I always remove all or at least most of it.
 When I do the video I will try it with just an iron and solder wick. And then maybe another video using the desoldering station and hot air station.
 In that video is sure look like he had left most of the old solder with the chip quick in it.Comment
			by howardc64Problem
 This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
			by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
			by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
 I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
 I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
 Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
 screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM
			by woody-009Hi Everyone
 I'm after some tips on how to remove a VERY stuck memory chip on an RTX2070. I am a beginner with this size chip so I bought an old non working GTX960 and I can remove and refit the memory chips to that with ease.
 So far I have cranked my hot air station to as high as it will go (It says 450C but I have no way to confirm that but its hot... its a cheap ebay unit. And I have a large square nozzle and have tried smaller nozzles.) I cant get the solder balls under the chip to melt. It has taken some flux in under it but still wont move. I have chipped one of the...
			This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...09-07-2024, 03:10 AM
- Loading...
