LG 50PJ350 - No pucture only Sound
  • frankiek3
    • May 2013
    • 5
    A recent lightning storm took out a LG 50PJ350 TV (and a Cisco DPC3939 router), on to the LG 50PJ350:
    No picture but sound is working (through atsc coax input)
    Shorting 'Auto Gen' (LVDS and Main board cable disconnected) produces visible test pattern
    Control board LED on when only 5V Standby connected
    Main board suspected, surge possibly went through an hdmi input
    More to test and I'll update the thread when I do.
    I'd like to repair the components on the board then just swapping it. I haven't seen any visible signs of damage. Anyone successfully repair a main board like this? I'll be testing with a (hopefully) working main board just to be sure. So I should have a reference.
    Pictures and 'Training' Service Manual to be added on request.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 50PJ350 - No pucture only Sound
    Just replace the board--Mains are notoriously difficult to trace faults on and to repair, as there's very little--often no schematics available for them, and any damage while de-soldering/replacing parts is normally fatal--as they are multi-layer boards.....
    save yourself the hassle--Just buy a replacement from a decent vendor...
    TELEFIX
    • frankiek3
      • May 2013
      • 5
      Well I haven't gotten the chance to dive into it as I was working on the router. I don't mind attempting a repair on the board since it would be scrap anyway.
      99% sure that the surge came in through the hdmi port (connected to a shutdown mac mini ).
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
