Samsung UN40B6000vf /xza clicking noises
  • nosaj
    • Dec 2014
    • 53
    Re: Samsung UN40B6000vf /xza clicking noises
    Originally posted by budm
    " When I unplug connector CNM802 that goes to the AV board it will power on then the LED lights up bright white." You already verify that the power supply board is OK (but the 5.2V STBY may be not) by removing the cable between the main board and the power supply, you saw that the backlights do come on.
    You need to have all the cable connected and find out first if the 5.2V standby is steady (this Voltage must be steady under load), if it is, then you need to look at the POWER ON/OFF pin to see if it goes up and down in sync with the clicking of the relay.
    Ok got the measurement but with connector plugged in I can only check the odd numbers. The 2nd number after slash denotes voltage change.
    thanks,
    Jason
    Pin 1 Power on/off .8 / .6
    Pin 3 Standby 5.2v 5.2 / 5.2
    Pin 5 GND_Vamp
    Pin 7 Vamp12.8 12.7 / 0
    Pin 9 GND_5.3v
    Pin 11 GND_5.3v
    Pin 13 5.3v 5.3 / 0
    Pin 15 5.3v 5.3 / 0
    Pin 17 GND 12v
    Pin 19 12v 12.6 / 0
    Pin 21 12v 12.6 / 0
    Pin 23 BL on/Off
    Pin 25 E-PWM 3.3 / .2
    Pin 27 DET (5v) 5 / 0
    Pin NC
      OK, so the standby 5.2V is feeding the main board with steady Voltage but the main board is sending unstable Power ON/OFF signal to the power supply board.
      So the problem is some where on the main board. You may try disconnecting the T-CON board to see if it will become steady, if not there will be more details troubleshooting of the main board.
      • nosaj
        • Dec 2014
        • 53
        Unplugging T-Con (flat cable with metal connector) Makes no change on the power on/off voltage .8 /0 varies .8 /.6 also.
        Thanks,
        Jason
          Well, something on the main board is bad, exactly what it is I do not know.
          one pin I am not certain is the DET (5V), not sure it is going up and down because the switched 5.3V is going up and down or something else.
          At this point I would say you have bad main board, someone else can chime in if they have worked on this model before with the same symptom.
          • d2fx
            • May 2015
            • 25
            • french west indies
            hello
            use the troubleshooting diagnostic no power I've sent
            proper dc standby ok===>proper 12v;13v;5v ok====>3.3v at pin 5 of ic202 ???
            no :ic202 hs
            yes :go ahead 3.3vpin1 ic208......
            • nosaj
              • Dec 2014
              • 53
              Originally posted by d2fx
              hello
              no :ic202 hs
              Yes I think.. On that IC there are 3 legs on one side and 2 legs on the other. I took a chance on the side with 2 legs. One of the legs gets 3.3 volts, The other is one volt but the funny thing is when i test that one with 1 volt it quits trying to power cycle.
              I will try to locate ic208. It's still hard even with your sheet.
              Thanks,
              Jason
              • d2fx
                • May 2015
                • 25
                #27
                Hello Nosaj
                The problem seems to be on the motherboard is to replace completely or to confided your board to a technician
                the repair of the board requires equipment....
                regards
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
