Toshiba 32HL95 No Audio - Where is Audio IC?
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
    09-06-2024, 05:27 AM
  • String2016
    TOSHIBA L755 NO audio problem
    by String2016
    I have here toshiba l755 laptop the problem is no audio device detected on windows tried installing drivers and tried also replacing audio chip still same issue. anyone encounter this please help
    03-04-2023, 01:58 AM
    09-06-2024, 05:59 AM
