have a toshiba 32HL95 that the sound quit working on it, sounds like a typical issue with the audio IC but man this thing has a tons of boards and they are all buried behind one another. Can anyone tell me where the IC is at? I'm going to try a reset but I've heard that is a temporary fix if it works at all.
Toshiba 32HL95 No Audio - Where is Audio IC?
Re: Toshiba 32HL95 No Audio - Where is Audio IC?
Service manual:
http://www.badcaps.net/forum/showthread.php?t=24809 -
I will have to look through the diagram. All you have to do is just to trace back the connection from the speaker connectors as shown in the diagram, which should then be connected to the power amplifiers.
The problem may also be the audio processing circuit not the output circuts.Never stop learning
yeah I followed those back and they went to the audio input board and I only saw one chip on the top side of the board but didn't think it was it. Any suggestions on how to test once I locate the chip? I guess for shorts? Hate to scrap this tv but not really worth buying whole board. My repair success ratio is getting lower lately. My first 3-4 were simple now I'm stuck with 4 I can't diagnose :-(Comment
So you lost sound from both speakers, then it has to be something that is common to both channels. You can check and verify if the ICs are getting the proper Voltages first.
Do you have proper tools to do SMD repair? You can also look up the spec sheet of the IC to tell you what the IC is for.
BTW, did you verify that the speakers setup in the on screen user menu is not set to off?Never stop learning
yeah I went through the menu to look for that but I will confirm one more time before I spend more time on it. I have an smd workstation and usually dont have a problem removing/replacing. Once I locate the proper ic I'll test the voltages, thanks.Comment
The TV also has TOSLINK Digital out that you can see if you get the sound from there, you will need an adapter though.Never stop learning
BTW, do you have oscilloscope or audio signal tracer?Never stop learning
Well, you are going to need tool to look for the missing signals, but at this point you should make sure first that the circuits have all the needed and the correct Voltages for the circuit to work.Never stop learning
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by String2016I have here toshiba l755 laptop the problem is no audio device detected on windows tried installing drivers and tried also replacing audio chip still same issue. anyone encounter this please help
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
