Tnpa5340 tnpa5341
  • Nick's Tvs
    • Jan 2014
    • 621
    Tnpa5340 tnpa5341
    I sent my SC board for repair TNPA5351 because the VS line was shorted to ground, and had several bad Diodes on the board.
    I get the board back, but the tv still doesn't turn on.
    At this point I have a bad buffer, but I don't know how to figure out which one is causing the issue, and how do I figure out which IC or IC's is or are bad. Is there an Ohms test I can perform, or some other sort of test?
    Thanks in advance for any help on this
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Tnpa5340 tnpa5341
    Anyone know anything about these buffers? Any help would be appreciated.
    • tw2005
      • Oct 2011
      • 6458
      open the manual, go to block diagram 4/4
      identify Vfo,VF5V, VSCN-F on sd,su. it gives the pin numbers at the connectors
      measure resistance -vfg for each
      Vfo usually will show short if the buffer has gone
      as far as repair, i'd get a pro to do it unless your really skilled and able to get those off as the tracks liftt and tear easy
      modus do buffers too
      • Nick's Tvs
        • Jan 2014
        • 621
        Yeah I am not that good with soldering, I don't trust myself with replacing one of those IC's
        but I just want to get an idea of which IC is bad and if both boards are affected or just one.
        Thanks for the tip.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
