Lg50ln5400
  • Lireb93
    • Dec 2012
    • 20
    Lg50ln5400
    Have this TV that does not have any picture but has great sound. Looked at many YouTube videos and finally opened up the TV. It has I believe, a main board, T-Con board and a power supply(which I believe to be also the LED driver as well as controlling the backlights EAX64905501) From what I have learned from the videos that I have viewed, it is the power supply. It has no back lights whatsoever but has real clear sound. Any assistance would be greatly appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg50ln5400
    Probably has an open LED.
    Picture of the power supply.
    If it does have an open led you'd need to have to decent experience of dismantling and assembling TVs to repair it as the whole panel will need to be removed.
    • Lireb93
      • Dec 2012
      • 20
      Re: Lg50ln5400
      LED part of the power supply? Backlight control also a part of power supply? If so I will just change out the power supply.
      • Hamie
        • Apr 2014
        • 1383
        Re: Lg50ln5400
        You'll need to check the voltage going to the back lights.
        If you have sound but no backlight the chances are the LEDs are at fault and not the powersupply.
        • mmartell
          • Oct 2013
          • 3189
          Re: Lg50ln5400
          Leds are INSIDE the panel, beneath the lcd screen.
          • Lireb93
            • Dec 2012
            • 20
            Re: Lg50ln5400
            Do I access from the back since it is already open or do I have to go through the front by taking out the screen?
            • mmartell
              • Oct 2013
              • 3189
              Re: Lg50ln5400
              There is no access from the back, you must go through the front. The repair is not so easy - the manufacturer would write this set off instead of repairing it.
              • Lireb93
                • Dec 2012
                • 20
                Re: Lg50ln5400
                Is the LED driver inside with the backlights or is it a part of the Power Supply?
                • mmartell
                  • Oct 2013
                  • 3189
                  Re: Lg50ln5400
                  Have no idea as you didn't supply pictures.
                  If it's like most led tv's the led driver circuits are part of the power supply board from which some wires will disappear into the panel to drive the leds inside.
                  • sgabrie8544
                    • Feb 2016
                    • 10
                    Re: Lg50ln5400
                    I have the same issue on a LG50LN5400, i disconnected the connector from the power supply pcb going to the LED strips and I still have no DC voltage at the connector on the power supply PCB. Should I replace the power supply pcb or could it still be an LED strip?
                    THX
                    Steve
                      03-31-2024, 02:12 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      07-01-2024, 06:34 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
