Lg 42pc1da
  • PSYKOCONNELL
    • Jun 2015
    • 4
    Lg 42pc1da
    I have one of these plasma beasts. I got it for free, with no remote or power cord. I found a compatable power cord and plugged it in. Without touching anything, there was a click, the white LED at bottom center blinked a few times, then another click and the LED was red. This all took place within 3-4 seconds. That's all the TV will do. I pulled the back cover off (I waited long enough for the caps to discharge) and examined the boards. All the capacitors look fine, none are bulged indicating a rupture. I checked all the fuses on the boards with my multimeter, found one bad fuse on the ZSUS board. I've done some researching online and a majority of the "how to" vids on youtube and links are about changing the caps.
    So, this is a 42 inch plasma TV that so far has cost me nothing, would be a nice TV to have, is it worth time/effort to troubleshoot further and see what it needs to make it work? What do you guys think?
    For the record, it's an LG 42PC1DA-UB, date of manufacture 2006....
    I appreciate any tips and help guys, thank you!
  • mmartell
    • Oct 2013
    • 3189
    Re: Lg 42pc1da
    In my opinion it is not worth the time, unless you are interested in learning what makes it tick and how to repair it.
    Blown fuse on the zsus likely indicates the ic under the large heatsink (IPM) needs replacing - not easily done without the right tools.
    Even as it is it should boot and have a shitty pic but you have nothing, indicating there is something else wrong, maybe power supply caps maybe something more insidious.
    THEN when you get it repaired you might find the thing to have wicked maldischarge which may or may not be curable.
    On top of that the IPM's cannot be had new so a used replacement puts your newly repaired set on borrowed time.
    All that being said I will say when working properly they throw up a nice pic
    • PSYKOCONNELL
      • Jun 2015
      • 4
      Re: Lg 42pc1da
      well with your input and lack of any other responses, I think I will kick this TV to the curb....moving soon anyway and I'm not going to drag this thing around if it's dead....
      will look into recycling it.....thanks mmartell
      • vestaviascott
        Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
        by vestaviascott
        I'm looking for the dial cord winding settings for this radio!
        I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
        The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
        06-07-2020, 08:36 AM
      • Zentech
        Lenovo Thinkcentre Turns On When Power Cord Plugged in
        by Zentech
        I got a Lenovo Thinkcentre MT-3218 that when I plug the power cord, the computer turns on. The power button seems to work just fine. When I press it the computer turns off, and when I press it again, it comes back on. But when I unplug the power, and plug it back again, it turns the computer on... does anyone have an idea what might be causing this strange behavior. Could this be the power supply or a bad contact on the power button?
        thanks
        PS: everything else on the computer works fine
        06-27-2021, 12:30 PM
      • gamartinelli
        Asus VG248QE won't power on / purple light
        by gamartinelli
        I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
        09-29-2022, 04:15 PM
      • spleenharvester
        Weirdly specific reboots on a TrigKey S5 that seem to be power supply related.
        by spleenharvester
        I have two of these mini PCs: TrigKey S5 with Ryzen 5700U, 32GB RAM, 1TB NVMe SSD, Win11 Pro. They work very well for most uses. They are powered by a HuntKey 19V 4.74A brick with a standard DC5525 tip, which feels decently heavy.
        When the brick is connected to the system through a 1 meter DC female-male extension cord (18AWG so decently thick), the system will black screen and reboot when multiple objects are sliced simultaneously in PrusaSlicer. One object is OK. Literally any other activity on the PC is OK. It is just this one specific thing that causes a reboot. I tried running...
        09-15-2025, 08:43 AM
      • Giacomo Siffredi
        Obtaining Replacement AC Adapter & Cord for Sony DVD Player
        by Giacomo Siffredi
        Hello!
        I am trying to obtain a replacement AC power cord and accompanying adapter for a Sony DVP-S560D DVD Player. There are several identifying numbers on the existing cord: The cylindrical portion bears the name & number: TDK ZCAT2132-1130; The "gasket" portion bears two numbers: VM3073 and 282; and the yellow adapter which plugs into the power supply board bears the name: AMP.
        Where or which types of online/retail stores might I obtain a replacement AC cord for this unit? Thank you for your assistance!...
        10-15-2018, 03:00 PM
