Toshiba 32W3451DB Backlight Problem
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Toshiba 32W3451DB Backlight Problem
    Originally posted by Als_2014
    hi, Can i ask u if u have every single led for replacement, thanks
    Hello please watch my video, it shows how to test them and replace them:
    https://www.badcaps.net/forum/showth...Stacking+video
    • Als_2014
      • Jun 2014
      • 7
      • Italy
      Thanks I already watched it nice video, i also have had ur same idea having some strips got from the old tv i fixed before, pulling all strips and modifying the electronic circuit.But i think better if would be possible to find where to buy each single led to replace the burned one..
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok also, you can use 1w pure white smt Led to replace them with.
        • Als_2014
          • Jun 2014
          • 7
          • Italy
          hi i already fixed the tv back light led, having another old strip pulled out from a old tv, as well i did same way as u showed in ur video, it worked fine. thanks
          But about the 1w pure white smd led, what about the working voltage?
          • moonshadow1
            • Jun 2017
            • 6
            Hi I have the same problem with my Toshiba set, it has 2 led's failed on one strip and 1 on the other.
            the led's work on either side of the failed ones so am I correct in thinking that they must have failed short circuit in order to let the supply through to the next led in the strip.
            Would the power supply board sense that there are 3 led's off and would this be enough to cause the power supply board to "crowbar " itself off and shut down?
            I have watched ReecyBurger123 's excellent video and I would like to ask him if he would be willing to sell me two complete working strips ? or would he sell me 3 or 4 led's to repair mine?
            Thanks in anticipation of a reply, new member moonshadow1 Northumberland.
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              One bad led can cause shut down.
              • moonshadow1
                • Jun 2017
                • 6
                Thanks for your reply. D.S.
                • moonshadow1
                  • Jun 2017
                  • 6
                  ReecyBurger123
                  Do you have any idea where I can buy these from ? RS Components perhaps,or Maplins.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    Originally posted by moonshadow1
                    ReecyBurger123
                    I have used this guy in the past with no problems
                    http://www.ebay.co.uk/itm/VESTEL-VES...19.m1438.l2649
                    • moonshadow1
                      • Jun 2017
                      • 6
                      Thanks vinceroger69 I will check him out.
                      • moonshadow1
                        • Jun 2017
                        • 6
                        Thanks for the information vinceroger69, I bought some and he sent me 22 led's for £9 which included postage and they are exactly what I needed.
                        • pni
                          Backlight panel diffuser melt by backlight leds broken
                          by pni
                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                          10-12-2025, 12:08 AM
                        • Dobrowol
                          Asus GA402RK keyboard and kb backlight problem
                          by Dobrowol
                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                          04-28-2025, 04:30 PM
                        • ononos
                          LG M2362DP Backlight problem
                          by ononos
                          hello everyone!
                          As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                          I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                          So i decided to try to...
                          03-12-2023, 05:05 AM
                        • fanaticgames
                          Samsung UE32D4010 Backlight problem, led ok
                          by fanaticgames
                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                          02-22-2023, 09:46 AM
                        • delphi_firebird
                          Toshiba Qosmio X755 Charging problem
                          by delphi_firebird
                          Hello Guys,
                          I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                          - When battery is unplugged i works without any problem.
                          - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                          - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                          Can you help me diagnose the problem? I have attached...
                          10-16-2023, 03:04 AM
