Isolation Transformer-Will this work?
  • tech2014
    • Aug 2014
    • 807
    I need an isolation transformer to do tv repair. Will this on work and can it be modified to work for TV repair on primary side?
    http://www.ebay.ca/itm/Hammond-Line-...item3f4b7d4862
    Re: Isolation Transformer-Will this work?
    Looks like it will but take note you will need a 230/240V input to output 115/120V.
    If you feed it 120V you will only get 60V out.
    It should support reverse operation as a step-up transformer, with 120V in on the secondary giving 240V out.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      http://www.ebay.ca/itm/Hammond-Isola...49441378&rt=nc
      Follow the white rabbit.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        If your handy with a grinder and a welder you can make your own out of a pair of microwave oven transformers. Just make sure they are identical cut the seam weld on the top of the laminated core, gently coax out the primary coil and replace the secondary coil in the other transformer, spot weld back together and wire in a cord on one side and a plug on the other. Mine was made of all recycled parts for free.
        Liberating magic smoke one part at a time
        • R_J
          • Jun 2012
          • 9552
          I made one out of an old microwave transformer years ago, I just chopped out the secondary winding and re-wound it, I can't remember the wire size I used but it worked out to be about 1 volt per turn. The transformer does run a bit hot due to the welded laminations.
          Now I use a large transformer and isolate the whole bench.
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • hollox123
            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
            by hollox123
            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
            1. Laptop keyboard doesn't work
            2. The backlight on the laptop keyboard doesn't work
            3. The x2 side LEDs (red) on the laptop don't work
            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
            But I am strongly aiming that it is somehow a BIOS-related problem,...
            05-11-2025, 08:05 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 04:40 PM
