TV: 50PG20-UA.AUSLLJR
Power board: EAY41360901
Good morning. I'm looking for a little help in diagnosing (rediagnosing?) this set that I am having trouble with. The problem was no power. No standby light, nothing. Opened it up and found Fuse F801 was blown and Caps C202, C203, C204, C218, and C917 bulging. As well as C201 on the YSUS board. From looking online I found that if fuse F801 continues to blow it is likely that transistors Q801 and Q802 were bad. Just those 2 transistors were about $6 a piece plus shipping from digikey and mouser, so I chose to order the "repair kit" from Shop Jimmy that had all the caps I needed (except the one for the YSUS board, but I had an acceptable replacement in my parts bin) plus the transistors and more.
Here is everything that I replaced using the kit.
Fuses F801 (came with the F101 fuse as well but mine wasnt blown)
Transistors Q601, Q602, Q801, Q802
Caps C202, C203, C204, C207, C218, C917
ICs U101, U801
Also, Thermistors TH101 and TH102 were bad (cracked and missing pieces), so I replaced them as well.
I replaced all of these parts, hooked everything back up, and Fuse F801 blew again immediately upon plugging in the set. I double and triple checked all of my solder points for shorts and don't see any issues there. Obviously there's something else bad but can't for the life of me figure it out. I'm hoping you guys can help me pinpoint this issue. Pics are attached, thank you in advance!!
ICs U101, U801
