Sony Bravia 52W5500 No HDMI input whatsoever, everything else works
  • ollihd
    • May 2015
    • 6
    • finland
    Hi All,
    I have a problem with my my Sony Bravia 52W5500 tv. A few weeks ago all of the HDMI inputs stopped working. I'm guessing it might be a power surge, but i really don't know. I have tried the following:
    - Changed HDMI cables
    - Tried to send HDMI with different devices
    - Done the factory reset a dozen times
    - Went to diagnostic mode and everything was fine
    - Tested all other inputs, all work fine (basically everything except the HDMI is working correctly)
    - No leds are blinking (tv is behaving as usual)
    I have opened the tv now and inspected the boards. I cannot see anything visually wrong (for example burnt) and all the little tiny fuses measure fine.
    Could someone direct me in the right direction? I have no idea how to continue.
    I'm a fairly skilled with the soldering iron so I would like to fix this as much as possible vs. just replacing a board.
    Thank you already in advance!
  • mmartell
    • Oct 2013
    • 3189
    Re: Sony Bravia 52W5500 No HDMI input whatsoever, everything else works
    Hdmi ic may need replacing.
    • ollihd
      • May 2015
      • 6
      • finland
      Ok, good idea. Any other things to check before changing the IC?
      • mmartell
        • Oct 2013
        • 3189
        Check all voltage regs for proper output, maybe you're not getting 5v to the ports ? Or if there's a separate switcher it may have failed or of course the main ic may have failed in some way. No easy check here as far as I know unless maybe you can scope those lines.
        • ollihd
          • May 2015
          • 6
          • finland
          Will measure the voltage regs. Thanks for the suggestion. I also noticed that the TV recognizes that a HDMI cable is plugged in. Does this info help? By this I mean, I see that for example HDMI2 is plugged in when cycling through sources(when a cable is indeed plugged in to the HDMI2) Same goes for all the inputs.
          • mmartell
            • Oct 2013
            • 3189
            That's an interesting fault. I'm not savvy enoigh on hdmi protocol to say what has failed here (could be data lines, port poweretc). Maybe reading up a little on the hdmi spec will give you some further insight.
            Dunno if there is a discreet xtal for the data lines but I suppose that is another option.
            • ollihd
              • May 2015
              • 6
              • finland
              Ok.. Measured directly from the HDMI-ports, and indeed they are getting voltage. 6.3VDC to be exact. Could the 1.3 "overvoltage" be the cause, or is it regular for the port to give over 5VDC?
              • newtothis
                • Mar 2013
                • 1556
                • england
                On PS3's when no display but it is recognized it is the HDMI IC that has failed and swapping the IC sorts it. Should be the same with TV's inputs I suppose
                • ollihd
                  • May 2015
                  • 6
                  • finland
                  Starting to seem like the IC, yes... Well I suppose I have to change it, if no other suggestions arise? I feel like i have tested everything that could be related to the problem.
                  • PopsCaps
                    Sony Bravia KDL-40V2500 that will not power on
                    by PopsCaps
                    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                    I do not hear any sound and I cannot see any backlight.
                    I have tried disconnecting every cable on each board one at a time to see if anything changes.
                    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                    03-25-2025, 11:23 AM
                  • justin35
                    Sony bravia kdl-43w755c - boot loop
                    by justin35
                    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                    from what i read online it looks to be an emmc issue…
                    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                    i took out the board and say an samsung 16gb emmc
                    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                    i could try to put one instead of the 16gb one, but will it work?
                    where do i get the software from?
                    any help will be much appreciated!...
                    03-06-2024, 12:26 PM
                    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                    10-16-2024, 05:15 AM
                  • Spc.
                    Sony Bravia KD43XF7596BAEP - Android no picture
                    by Spc.
                    Greetings everyone.
                    I also have Sony Bravia, model:
                    Sony Bravia KD43XF7596BAEP - Android.
                    What happend is that image dissapeared while we were watching tv.
                    Diagnostics:
                    1. TV turns on, no errors
                    2. Backlight turs on, no errors
                    3. Power indicator turns on, white color, no errors
                    4. Menu works on android, you can hear sound while switching channels
                    5. Volume up and down works via TV remote and via buttons
                    6. Tunner works, HEVC / MPEG-4 decoder works
                    7. I get audio from channels
                    8. No picture is present,...
                    05-19-2022, 04:28 AM
                  • KYBOSH
                    Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                    by KYBOSH
                    Previous owner said TV just went blank one day.
                    They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                    Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                    The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                    There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                    I just downloaded the Sony KD-75X7800F Service Manual and...
                    11-19-2024, 10:12 AM
