Samsung LE37B551A6W - white screen
  • marcinbjl
    • 5
    • England
    The problem with this TV is white screen.
    Main board - bn41-01258a
    Power supply- BN44-00262A
    T-CON- T370hw02 VC 37T04-C0G
    Voltages from PSU:
    5.3v pin - 5,31v
    13v pin - 12,3v
    T-con voltages:
    VGMA1 15.36
    VGMA2 15.11
    VGMA3
    VGMA4 12.45
    VGMA5
    VGMA6 10.74
    VGMA7
    VGMA8 10.05
    VGMA9
    VGMA10 7.95
    VGMA11 7.7
    VGMA12 6.76
    VGMA13 7
    VGMA14
    VGMA15 4.86
    VGMA16 2.9
    VGMA17 4.23
    VGMA18
    VGMA19
    VGMA20
    VGMA21 0.52
    VGMA22 0.3
    AVDD 15.96
    VGL or VOFFE -6.07
    Is it problem with Gamma chip or maybe too low voltages from PSU? What else can i check?
    thank you for any help
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung LE37B551A6W - white screen
    Gamma IC
      Agreed
      • marcinbjl
        • 5
        • England
        ok thanks, i am waiting for a new chip and will try to replace it
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
          by JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
          Please help. Thanks in advance!
          08-12-2025, 11:45 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
